fork conversion
geos59bug
fork conversion
will 1995 kx 125 forks fit 05 kdx200? and what tripple trees should be used. my forks are leaking and figure just do the conversion. new to the forms any help would be great thanks.
The conversion process is the same for any conversion.... may as well READ up on it in the Sticky
roadkillrobert
Everything fits, just a matter of moving the stem over and some other work, do a search, others have done it. Ultimately, the newer the better, the 1995 upside downs are not really much better than the KDX forks and they have a fair amount of overhang. If your looking for functionality, 99-01's are the best place to start for the money, newer are better and more money, but many have done the 99-01's including myself and it is a pretty easy mod and well supported (like Ron Black makes the spacer you need for the top triple etc). If you just want upside downs, or are doing for a more modern look, the 95's will certainly work fine.
