Page 1 of 2
Whole front end or just new springs?
Posted: 11:08 pm Mar 14 2010
by sportsgirl017
So obviously the front forks on the KDX are grossly undermanufactured. And it seems like the concensus is to rebuild the front end.... however if you can just buy properly rated springs (racetech 109$) wouldn't that be enough? Trying to buy all my parts now so I'm ready to mod and ride ASAP once back in the states.
Posted: 11:12 pm Mar 14 2010
by Indawoods
It's probably enough if you just trail ride and are not agressive at all on the trails... a family rider.
Posted: 11:14 pm Mar 14 2010
by Mr. Wibbens
Stockers properly sprung work good for me
Seemed to work fine for Fredette all those years too
Posted: 11:27 pm Mar 14 2010
by Indawoods
When you are factory sponsored.... you bet ya!
Posted: 01:00 am Mar 15 2010
by Mr. Wibbens
Indawoods wrote:It's probably enough if you just trail ride and are not agressive at all on the trails... a family rider.
Good thing I'm just a family rider then
Posted: 01:04 am Mar 15 2010
by Indawoods
Your rare.... I will give you that.
Posted: 01:09 am Mar 15 2010
by Mr. Wibbens
My suspension is better than it has ever been
I'm loving it!
Posted: 03:58 am Mar 15 2010
by sportsgirl017
So basically the whole front forks are crap? Definitely not just a family rider......
Posted: 06:34 am Mar 15 2010
by KarlP
The stock forks with the right springs and oil work pretty good.
A carefull revalve front and rear will make the suspension pretty darn good.
When I put a KX front end on, it was SO much better, can't really compare.
Posted: 07:31 am Mar 15 2010
by sportsgirl017
Thanks Karl for the objective response.... think I will do springs for now. Save the KX front for a off season down the road.
So tell me how great the RB mod really is, from what I hear it's basically amazing....
I'm beginning to see a mass overhaul in my future
Posted: 07:56 am Mar 15 2010
by KarlP
I've always ran the bigger and better 220 motor.
When I had a RBD modded motor in a Kwasaki frame with a KX front end it was great. Just my impression, but I think the head mod did more for the motor than the carb work. For $45 it is certainly the most bang for the buck.
With the carb done, head mod, and a pipe the motor ripped. Great tourque down low, more overrev than I could use in that chassis.
After I moved the motor to a CR chassis I used a CR pipe. I think the motor works better than it did in the KDX frame, obviously getting lucky with the pipe. I've swapped with guys on KTM and GasGas 200's and I got more motor. Less overrev, but more motor. For woods riding it is perfect for me.
3+ years on that build and still going strong.
Posted: 08:18 am Mar 15 2010
by AST236
KarlP,
What part of Alabama? I"m halfway between Montgomery and Mobile. Just picked up a 2000 220.
Posted: 08:36 am Mar 15 2010
by KarlP
Theodore, 20 minutes West of Mobile.
Posted: 10:59 am Mar 15 2010
by AST236
KarlP wrote:Theodore, 20 minutes West of Mobile.
Sweet! I"m in Evergreen, 100 north of Mobile. Just got my first KDX. First two stroke since high school (30 years ago). Where do you ride? Have you tried the track/trails in Brewton?
fhigginbotham@evergreenmedical.org
Posted: 11:23 am Mar 15 2010
by KarlP
I rode a harescramble last year in Brewton. It was fun and well run.
Funny thing. They did a dead engine start and you had to run over from behind the next row. I did not know this until we got to the line. Most people have a kickstand or brought one of those axle stands.
I laid my bike down on the ground. Fired right up and off we went!
Got a lot of funny looks.
If you have any plans to get into the Mobile area, get in touch. We have some good riding here.
Posted: 01:24 pm Mar 15 2010
by AST236
I'll do that. I hope to get to Brewton in the next few weeks and check them out. It's only about 30 minutes from my house. How are the trails? Did you ride the track?
If you don't mind, I may lean on you as I"m learning this new bike. From what I've read, I'm on borrowed time if I have a stock piston, so I guess I'd better plan to do the top end pretty soon. I"ve never done one so it should be an adventure.
Where do you ride in Mobile?
Posted: 01:49 pm Mar 15 2010
by scheckaet
Piston swap for a wiesco, the sooner the better.
Not very hard, you only need gasket, piston kit (with bearings, wrist pins, clips...)
When you take it apart, be careful to SUPPORT the KIPS shaft when you remove the nut at the top (left tread). Do same at reassembly.
Get the manual if you don't already have one, it's pretty well explained (aside for supporting the shaft, everything is explained) Good luck
Posted: 01:53 pm Mar 15 2010
by Indawoods
What does that have to do with the front end and springs?
Posted: 02:17 pm Mar 15 2010
by AST236
Nothing.
My fault. I saw another rider from nearby and started a conversation.
Posted: 09:33 am Mar 16 2010
by fuzzy
In a nutshell the susp can be made to work great after springs/valving/etc, but most on here have replaced the susp with KX parts for the same or less money, and of course gain more.
