Page 1 of 3
kips problem
Posted: 06:55 pm Mar 11 2010
by pinitwot
so i got my bike back together after doing my first top end. started right up first kick :supz:
so i pulled this side cover thing off to vew to make sure the kips are working and guess what they are not. :oops:
from what i have read is that the shaft in there should move when its reved over 6000 rpms. and mine doesnt. it reves fine though????????
is this true?
the only part i messed with is the part where it conects to the top end.
anyone have any ideas that might be causing this?
also when i had the bike apart i saw that the kips thing was all the way open in the exhaust port is this how its supposed to be when its taken apart? also how easily should the shart turn when you have the cylinder off?
thanks! please help
[/img]Image
Posted: 07:08 pm Mar 11 2010
by scheckaet
the main valve should be close when the engine is off.
Did you support the shaft when you put the left treaded nut on?
Maybe your kips actuator is broken? (really bad if you run it like that)
Posted: 07:16 pm Mar 11 2010
by pinitwot
ok so when the engine is off there should only be a little gap? cuz on mine i think it was all the way open?
do you have a pic of when it would be closed?
and i dont understand what you mean by (supporting the shaft when you put the left threaded nut on)???????????//
and how do you get to the kips acuator, and tell if its broken?
Posted: 07:38 pm Mar 11 2010
by Julien D
On the right hand side of the engine is a shaft that comes up from the bottom end to engage the gear for the KIPS valves in the cylinder. If you do not support that shaft when loosening or tightening that LH thread nut on top, you can break off the pin at the bottom of the shaft that rides in the KIPS governor. That pin then floats around and usually lays at the bottom uselessly, but could get snatched up by the clutch or main gear and cause some real damage. To get to the governor and pin you have to pull the inner clutch cover off the RH side of the engine.
Posted: 07:45 pm Mar 11 2010
by pinitwot
oh. so i just take the clutch cover off and look in there?
that very well may be the problem, cuz i did not hold it while tighting it.
they need to put that in the manual.
and i no my kips turn cuz i put a nut driver on the bolt that is on the end of the shaft in the little inspection hole (the pic i psted earlier), but how easy sholuld it turn?
and how easy is it to get a new pin? and how much does it cost?
Posted: 07:46 pm Mar 11 2010
by Indawoods
It is in the manual! :lol:
You don't just remove the clutch cover but also what the clutch cover is attached too....
Posted: 07:53 pm Mar 11 2010
by pinitwot
ok im i going to have to take the clutch out too?
Posted: 08:00 pm Mar 11 2010
by Julien D
No, I think by that he's referring to the INNER clutch cover. The little round cover is your clutch cover, the larger cover that mates to the center case is the inner clutch cover. You must remove it. The clutch does not need to come out. The governor rides in a bearing in the inner clutch cover and another bearing in the center case. So when you remove the inner cover it just falls out.
You have a manual? It's all in there. The pin is available at OEM parts dealers.
Posted: 08:12 pm Mar 11 2010
by pinitwot
ok thanks i will have to check, im guessing that is the problem,
but also wondering how easy should the shaft in the pic, how easy should i be able to turn it with a nut driver?
Posted: 08:15 pm Mar 11 2010
by Colorado Mike
pretty danged easy.
Posted: 04:54 pm Mar 12 2010
by pinitwot
ok well i took it apart and i see no pin??????? all i see is this thing it looks like it is broken???
is this the pin?
also i would like to know turning the kips shaft on the right side (with the gear on the end) of the engine wich way is opening the valves?
and if i turn them open should they stay open or are they on a sping and go back closed as soon as i let go of the shaft???
[img][img]http://i687.photobucket.com/albums/vv23 ... G_0181.jpg[/img][/img][/b]
Posted: 05:26 pm Mar 12 2010
by Indawoods
Hmmm.... something tells me you don't have a manual. All this stuff is in there. The KIPS is a very complex system and you will not see a the overall exhaust port do anything.....
The pin is on the other side of that flat metal piece attached with 2 allen bolts if it's there.... looks like toast to me.
Posted: 05:41 pm Mar 12 2010
by scheckaet
Seems like you need to check this:
http://www.cyclepedia.com/amember/signu ... up=CPP-102
it's cheap and a must have
Posted: 06:10 pm Mar 12 2010
by pinitwot
thanks but i already have the stupid manual.
when i look in the exhaust port i can see the little flaper and i can see it move up and down a little.
but also i would like to know turning the kips shaft on the right side (with the gear on the end) of the engine wich way is opening the valves?
Posted: 06:16 pm Mar 12 2010
by Indawoods
That broken piece and pin that your missing.... is what actuates the KIPS and makes the whole thing work. :wink:
Posted: 06:35 pm Mar 12 2010
by Green Hornet
The governor is a $20 part & you will need a right engine case gasket & clutch gasket. It does not state in the manual that you have to support the KIPS Shaft (at leaast mine didn't) Also the nut that connects to the claaw is a reverse thread.
Posted: 06:39 pm Mar 12 2010
by Indawoods
You are correct! It has been years since I looked at that part. They just state that it is left hand threads... nothing about supporting the rod.
I guess being in the know you just assume others know.
Posted: 06:40 pm Mar 12 2010
by scheckaet
Don't forget to FIND as many broken pieces as you can before you ride...you probably ought to remove the clutch and gear and make sure no pieces are hiding there, could cost you a lot, ask me how I know...
Posted: 06:44 pm Mar 12 2010
by Green Hornet
This is the problem area
Posted: 06:51 pm Mar 12 2010
by scheckaet
we need somebody to design something stronger and better than the oem cast crap POS. Any volunteer? :?
