Page 1 of 2
1993 kdx 200 main jet and pilot jet?
Posted: 07:49 pm Mar 04 2010
by matt forstrom
does anybody know how to tell if your bike is jetted right? also what did the 1993 kdx 200 come with stock from the factory for jet sizes main jet and pilot jet? I do not race it or ride it hard. I am simply gonna use the bike for riding around in the woods.
Posted: 08:02 pm Mar 04 2010
by Indawoods
Stick a 155/45 in there and ride. :wink:
Posted: 07:27 pm Mar 05 2010
by matt forstrom
so heres the deal haha, I pulled my carb apart and it has a 180 main jet and a 48 pilot jet. the bike has a FMF cold series pipe on it with the stock silencer. Is this combo really rich as far as the jets go? Would you still recommend me putting the 155/45 combo in like you said before?
Posted: 07:33 pm Mar 05 2010
by Indawoods
Uh yes to both.
Posted: 07:36 pm Mar 05 2010
by matt forstrom
thanks alot :grin: do I have to worry about the bike running too lean causing engine damage or is 155/45 pretty safe?
Posted: 08:13 pm Mar 05 2010
by Indawoods
That is a safe jetting for anytime other than extreme cold.
Posted: 08:43 pm Mar 05 2010
by Julien D
Indawoods wrote:That is a safe jetting for anytime other than extreme cold.
I agree, completely. 155/45 is just about the best suggestion anyone can give you for jetting your KDX. The leanest possible combo that will likely be safe for darn near any elevation/condition. You can obviously do better than that by jetting it for your actual riding conditions, but you kinda have to do that yourself. There is tons of information available regarding procedure for jetting 2 stroke carburetors.
Anyway, 155/45 should run quite a lot better than 180/48 no matter where you are! This is assuming, of course, that the bike is mechanically sound otherwise.
Posted: 10:00 pm Mar 05 2010
by matt forstrom
thanks for the info guys! it really helps. I'm gonna order some new jets right away. The bike seems mechanically sound to me. it starts right up in 2 kicks when you choke it. you can turn the choke off right away and it will idle like a champ. oh, and by the way, my air mixture screw is turned out 1 1/4 turns right now. do I need to change that once I switch to 155/45?
Posted: 10:03 pm Mar 05 2010
by TWMOODY
Just out of curiosity, do you have to put in a new plug every 10 minutes with that 180 jet in your bike ??
Posted: 10:32 pm Mar 05 2010
by matt forstrom
I sure hope not haha. I have only been able to take my bike up and down the road a few times since I got it a couple weeks ago. theres too much snow where I live so I havent even tested it out yet.
Posted: 11:39 pm Mar 05 2010
by Tomm9050
Stick a 155/45 in there and ride. Wink
You might want to suggest a needle clip position...
Posted: 11:43 pm Mar 05 2010
by Indawoods
Most ride with the clip in the center of the needle as a starting point. That should also be safe.....
Posted: 10:06 am Mar 06 2010
by matt forstrom
should I mess with the air adjustment screw when I use 155/45? It is currently 1 1/4 turns out for 180/48.
Posted: 10:29 am Mar 06 2010
by Indawoods
Read the jetting guide to guide you through adjusting the air screw.
Posted: 02:50 pm Mar 07 2010
by 91kdx200
On my 91 KDX (same motor and carb), I run a 150 MJ, 45 PJ in the summer and am gonna try a 42 PJ. Bike runs awesome. In the winter I run a 160 MJ, 52 PJ and runs good. So for a main jet start out with a 155 as Inda suggested and work your way down. I don't know if I would try any lower than a 150. 45 is good for pilot jet, start with that and test a 42 in it to compare.
Posted: 03:07 pm Mar 07 2010
by Tomm9050
What needle and clip position?
I'm running 45pj/155Mj/1172 stock needle/ 3rd clip
fatty pipe/ stock exhaust/ Boyesen reeds
Posted: 03:44 pm Mar 07 2010
by matt forstrom
thanks for the info 91kdx! I ordered my new 155m and 45p jets yesterday, should be here tuesday. my air screw is out 1 1/4 turns so from what I read about adjusting that, I'm gonna bring it down to 3/4 turns out. I'm not sure what my needle clip position is but I'll check and put it in the center clip/notch.
Posted: 03:59 pm Mar 07 2010
by Indawoods
The air screw is adjusted for the current conditions not set at a specific setting. I suggest reading the Jetting Guide again.
http://kdxrider.net/forums/viewtopic.php?t=1156
Posted: 04:03 pm Mar 07 2010
by matt forstrom
alright thanks
Posted: 06:57 pm Mar 08 2010
by 91kdx200
Tomm9050 wrote:What needle and clip position?
I am running stock needle in the 3rd clip.
