Parts list?
- Has thanked: 6 times
- Been thanked: 10 times
Parts list?
Does anyone have a parts list on what parts should be replaced and what should be checked for replacement when doing a top and lower rebuild? Yes, I have the manual but I would like a simple and easy to read list if possible. Thanks.
- Has thanked: 5 times
- Been thanked: 12 times
It's a 2 stroke. Not a lot of parts in the top and bottom as far as a standard top and bottom rebuild goes.
piston kit (piston, rings, wrist pin)
rod kit (connecting rod, wrist pin bearing, big end bearing)
main bearings
crank seals
Compare that to a 4 stroke top and bottom, LOL!
You'll obviously want to check the cylinder bore, and inspect the KIPS valves.
Of course you'll need a complete gasket set. While you're in there might as well pull bearings from the tranny and match them up for replacement too. No , I do not have the item numbers for them. I just pulled them out and took them to the shop and got replacements.
main bearings
crank seals
