1. Should the steering stem bearings be replaced in pairs or can get away with just replacing the one that looks bad? Where can I get a replacement bearing, OEM from RonAyers or cheaper aftermarket elsewhere, CBR?
2. How do I remove the outer race from the head pipe without buying kawasaki's special tool. Somewhere in my reading I seem to remember a home built tool out of a short section of pipe with 4 cuts length wise distributed evenly around the circumference. The pipe was flared at the cut end so when the pipe is inserted though the head pipe the flared end is compressed down as it passes through the outer race then expands and seats itself on the lip of the base of the race as it passes though. Then hammer the on the pipe from the opposite end. Doses this work well? What kind of pipe to use? Is it difficult to make? What to use to make the cuts? OR Is there another way to accomplish this task? Does heating the head pipe help install and removal of the race?
BTW I have a steering stem bearing that looks good if you guys think the existing race can still be used. see pic
