Leaky Carb
Posted: 10:31 pm Feb 10 2010
by Tomm9050
I left the petcock open and came back to the bike after a while and there
was gas leaking out of the carb hoses. Is this normal? Besides shutting the petcock, is there a fix?
Thanks
Posted: 10:32 pm Feb 10 2010
by Indawoods
Adjust your float....
Posted: 11:07 am Feb 11 2010
by KDX4ID
I had the same problem on my '97. I adjusted the float about a thousand times, replaced the needle and spent waaay to much time on it.
I finally bought a new carb from Sudco ($200 and some change), problem solved .
Also, make sure your petcock is in good shape. When they get old rubber pieces flake off, migrate to the carb and get stuck between the needle and seat making it impossible for the float close all the way.
Posted: 11:48 am Feb 11 2010
by Indawoods
That's like saying my house has a crack in the ceiling... let's buy a new house.
This very very common on KDX's....
Posted: 12:32 pm Feb 11 2010
by Tomm9050
It's a new petcock so that's probably not the issue.
