Skid Plates, but not which one....
Posted: 09:25 pm May 26 2005
by clutchcover
I have a different kind of skid plate question. With all the different makes and types, answers make vary I guess. I recently made a steel skid plate for the old 200. Used 1/8" sheet metal, fabbed up some ugly clips and bolted her up. It's not the prettiest, or lightest, but it's near indestructable. My question is, whether anyone else gets an amplification of sorts of all of the notorious kdx noises. The first time I lit it up, I thought my bike was going to hell in a handbasket. I had to pull the skid plate ooff twice to make sure it wasn't just my imagination. The clutch being the noisiest, and followed closely by the sewing KIPS. Is this just my makeshift skidplate, or do all the skids out their have a similar effect? Maybe I worry to much. Anywhoo,
Posted: 09:34 pm May 26 2005
by Indawoods
Yup... reflection...normal!
Posted: 10:03 pm May 26 2005
by IdahoCharley
Second Yup... You will adjust to it over a few rides. May be a good thing actually once your ears are adjusted to it: It will make "strange" new noises louder/easier to hear.
Posted: 10:30 am May 27 2005
by Colorado Mike
I've heard of people stuffing foam in there, mostly to keep mud from building up and increasing weight. It might lessen noise though. I would be a little concerned about increasing heat. Mine has always had the plate on it though, so I don't notice the engine noise. Mine is some kind of hard aluminum and it really makes a loud "crack" noise when rocks hit it. Scares the crap out of me sometimes, sounds like the rod blew through the motor or something.
Posted: 10:40 am May 27 2005
by layoutd
i am fabricating a skid plate from an old street sign. do you have any pics of yours?
Posted: 10:45 am May 27 2005
by m0rie
What did you use for clamps to mount the skid plate to the frame?
Posted: 11:23 am May 27 2005
by canyncarvr
If you're making your own...or installing a new one..or have an old one...
(that about covers it?)
I drilled a hole under the shift lever so I could access the fastener through the plate. I replaced the hex bolt with an allen head, too.
That fastener may come loose (mine has once or twice), and being able to tighten it in seconds vs: minutes (if you have to take the plate off) is a good thing.
Yeah...you can usually get to it from the side..but that may well require the use of a 12pt. box-end wrench. Chances of rounding off the bolt head? Pretty good!
I don't recall any noise increase with the plate on. Sometimes ignorance and oblivion is a good thing!
Posted: 04:27 am May 30 2005
by KDXer
That explains why my Katie was chattering abit louder... Good work guys... Cheers
Posted: 10:17 pm May 30 2005
by clutchcover
Thanks for the input everyone. My skids not pretty in the least. I'll post some pics of the plate and clamps if I get a second.
Posted: 04:10 am Jun 03 2005
by 89kdx200rdr
put a pipe guard on thats a hole different new noise
Posted: 04:12 am Jun 03 2005
by 89kdx200rdr
morie i think it was 1 1/8" conduit clamps that came with mine
Posted: 10:07 am Jun 03 2005
by m0rie
Thanks, 89 that sounds about right.
Posted: 09:57 pm Jun 05 2005
by jafo
My skid plate came with a different kind of foam for a cavity filler to keep mud from packing betwen it and the trans case. Mine does'nt make any kinds of noise, sounds just like it always has.
Jon.
Posted: 06:55 am Jun 06 2005
by layoutd
i would still like to see some pictures of someof your skid plates. i have mine about half complete, just need to look at some different ones
Posted: 06:51 pm Jun 10 2005
by clutchcover
Here's a couple pics of my skid. Still in refining process. I used bent pieces of angle with a nut welded to them for the back clamps, and for the front I bent a piece of flat bar to fit over both sides of the frame. Then tapped them for the bolts.
Posted: 08:43 pm Jun 10 2005
by m0rie
Looks good to me clutchcover.
Posted: 08:48 pm Jun 10 2005
by Indawoods
Looks tough as nails!
