timing marks?
timing marks?
ive noticed upon inspecting the stator on my 03 220 there are 3 lines cast onto the inner engine case & on my stator there`s also a mark which lines up with the middle mark of the 3 .. im assuming this is the standard `factory` setting for the timing?..what do the other 2 marks either side of the factory setting represent..advance & retard??...my kdx seems to have developed a detonation symptom ive tried running super unleaded fuel 98 ron as opposed to normal unleaed 95 ron, ( UK fuel is not like what you guys in the states have) the detonation isnt that bad but its still there (my motor is standard & the bike is a canadian import & runs well)..would altering the stator 1 mark either way cure that knock??.. which way is advace & retard..clockwise or anti clockwise?? any help would be gratefully recieved..thanks.
One is advanced timing the other is retarded timing
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Don't go a whole mark... a slight bump can make a huge difference.
- canuckhybrid125
On a 2-cycle retrarding the timing gives more rpm and over-rev while advancing the timing gives more bottom end. (It is just the opposite of a 4-cycle in regards to the effects of advancing or retarding the timing)canuckhybrid125 wrote:clockwise advances the timing while counter clockwise retards the timing which will give you a little more bottom end.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
- canuckhybrid125
OK I let cyclepedia know.IdahoCharley wrote:On a 2-cycle retrarding the timing gives more rpm and over-rev while advancing the timing gives more bottom end. (It is just the opposite of a 4-cycle in regards to the effects of advancing or retarding the timing)canuckhybrid125 wrote:clockwise advances the timing while counter clockwise retards the timing which will give you a little more bottom end.
It Is What It Is
2000 KX KDX Hybrid
2006 KX 100
2004 TTR 125 LE
2010 KTM 300
2000 KX KDX Hybrid
2006 KX 100
2004 TTR 125 LE
2010 KTM 300
- fuzzy
head & piston stock ,we have had unusually cold weather over here for this time of year so wasnt sure if that was part of the problem..although my friend who i ride with is experiencing similar problems on his ktm 250 exc 2 stroke..we both fill up at the same gas station so perhaps it may be a bad batch of fuel??..with check for bad air leaks in the system...can i adjust the timing without removing the fly wheel???fuzzy wrote:Is your head/compression stock? No way it should be pinging with 98octane fuel. Look for leaks...on intake and exhaust. Can test for leaks with carb cleaner while the motor is running.
- fuzzy
Just letting you know the Cyclepedia manual has been updated on the ignition timing.
The most important thing it to keep a record of what you do, how it performs, and how you like it.
If you have questions cyclepedia has tech support.
http://www.cyclepedia.com/contact-us/
