Advancer Shaft Removal
Posted: 08:14 pm Jan 14 2010
by Varmint
I'm trying to the the cylinder off and I can't get a good grab on the bolt behind the advancer shaft. Will removing the little phillips head free up the shaft for removal? Will anything drop into the cases?
The manual doesn't even mention to remove the shaft!
Posted: 08:21 pm Jan 14 2010
by Indawoods
Why would you have to remove it?
Posted: 08:22 pm Jan 14 2010
by Varmint
Indawoods wrote:Why would you have to remove it?
The nut on the cylinder is unreachable with a wrench or socket. The frame or the shaft is in the way.
Posted: 08:24 pm Jan 14 2010
by Indawoods
Got a pic?
Posted: 08:31 pm Jan 14 2010
by Varmint
>|QBB<[/url]
Indawoods wrote:Got a pic?
Posted: 08:37 pm Jan 14 2010
by Varmint
Too scared to stick a 12 point on it. Maybe I should go out and buy a 6 point wrench.
Posted: 08:44 pm Jan 14 2010
by Indawoods
I use an offset 12 point closed end wrench....
Take that clutch cable loose too and get it out of your way.
Posted: 09:12 pm Jan 14 2010
by Varmint
I need a set of these in metric flavor...
I ran out to sears and they were closed. Just my luck. Going to the bar instead.
Posted: 09:13 pm Jan 14 2010
by Varmint
Indawoods wrote:I use an offset 12 point closed end wrench....
Ha, you posted while I was doing 65 in a 35 trying to get to sears before 9. Too bad they close at 8.
Posted: 09:20 pm Jan 14 2010
by Mr. Wibbens
Take right cover off?
Posted: 07:17 am Jan 15 2010
by Varmint
That'd work too!
Re: Advancer Shaft Removal
Posted: 01:13 pm Jan 15 2010
by Mr. Wibbens
VirtualVarmint wrote:I'm trying to the the cylinder off and I can't get a good grab on the bolt behind the advancer shaft. Will removing the little phillips head free up the shaft for removal? Will anything drop into the cases?
BTW, If it is anything like an E you have to take the cover off to remove the shaft.
Once the cover is off your problem is solved
Just watch the shifter return spring and kicker spring when you go to put it back together
Posted: 01:18 pm Jan 15 2010
by Indawoods
I never had to do that on mine.
Posted: 01:23 pm Jan 15 2010
by Varmint
I'm gonna buy a set of offset wrenches. I love having a reason to buy tools!
How can you possibly torque that bolt on reassembly?
Thanks guys.
Posted: 01:53 pm Jan 15 2010
by scheckaet
Use the hand torque wrench
Posted: 04:01 pm Jan 15 2010
by Varmint
Posted: 07:31 pm Jan 15 2010
by Brian
I use the torque wrench on the nuts I have access too and then put my box end wrench on them and feel how much force it takes to move them and then I apply about that much force on the nut I can't get the torque wrench on. Once you have gone around them a time or two they should all be torqued about even.
