newb here...
Posted: 07:00 pm Jan 11 2010
by brokemk3
hey all..im new to the forum and i have just recently bought a 93 kdx 200 and ive been having issuses with the kick starter. The kid i bought it from said he dosent know whats wrong with it but i need to find top dead center in order to start it. ITs so annoying it almost never catches and i have to slowly and when i mean slowly i mean snail slow lower the kick starter till it catches and then kick. what could be causing this problem?
Posted: 07:54 pm Jan 11 2010
by scheckaet
sounds like the gear kick starter is fubar. You probably need to open the right side cover (easy) and check it out.
Posted: 07:48 am Jan 12 2010
by Julien D
There's a couple gears in the kick starter mechanism that get worn out and cause that problem. The ratchet gear and spur gear.
Posted: 08:49 pm Jan 12 2010
by KDXsg
No worries, its a common problem.just cheak it out and if the kick mechanism is the problem, just buy off a good one in ebay.
Posted: 09:33 pm Jan 12 2010
by Julien D
I have a lightly used set of the gears you would need, if you determine that is the problem.
Posted: 02:59 am Jan 15 2010
by brokemk3
i dont really know much about these bikes im going to change out the gear oil and change my spark plug tomarrow becuase it came out black and nasty but other then that i dont think i would be able to open up the case i feel like im going to eff **** up.
side note: can you guys tell me what all this crap is ?
Posted: 04:05 am Jan 15 2010
by Taylord123
that is probably the brake light wiring
and i have a problem my kdx 1993 200 will stick the throttle and once i have killed it, it is fine the cable is extremly free and returns well
Posted: 04:07 am Jan 15 2010
by Taylord123
its really starting to piss me off
Posted: 07:43 am Jan 15 2010
by KarlP
The only nice thing about buying a bike with a goobered up kickstart mechanism is that the PO did not ride it much.........
Getting at that mechanism shouldn't be too difficult. The whole right side cover can come off without removing the motor from the bike, I believe. A number of people on here have experience with that mechanism - it does sound a little tricky to get back in there properly.
Brokemk3- I would not worry about that extra wiring at this point if the bike runs. Tape the ends and stow it away for now. It probably went to the tailight or head light. Someone may have put an MX rear fender on to make it go faster.
Taylord-
I'd carefully pull the throttle slide and cable and throttle mechanism on the handlebar and clean everything up and make sure it is together correctly. There is a plastic cable retainer inside the slide that is easy to put in wrong.
Posted: 08:48 am Jan 15 2010
by KDXsg
that is the voltage regulator. I own a 1992 KDX 200 SR model and that is to regulate voltage to your signal and healight etc...so that the lights always recieve a constant voltage as not to blow. if you find that you headlight always blow, chances are the regulator is faulty.
Hope I am correct.
Posted: 09:45 am Jan 15 2010
by Julien D
While you can indeed see the VR in his picture, the bunch of wires he's holding in his hand captioned by "what is all this crap" would be the wiring harness for the lights.
Posted: 10:33 am Jan 15 2010
by Colorado Mike
Taylord,
Sometimes an air leak can make you think the throttle is stuck. If the kill switch shuts the engine off and you restart it without moving the throttle, it would go back to a high rev condition if the throttle was really stuck.
If you have an air leak, you are running lean and will eventually blow your motor.
Posted: 07:54 pm Jan 15 2010
by Taylord123
where would the air leak come from as i do all the clamps up tightly to the carb and the gasket is in good condition where it meets the reed block
Posted: 07:57 pm Jan 15 2010
by Julien D
base gasket, head gasket, crank seals, case halves, intake manifold... Umm... that's all I can think of off the top of my head.
Nice thread jack btw....
Posted: 08:50 pm Jan 15 2010
by KDXsg
Form the picture, it seem like the VR is not connected as well. Do a top end overhual and service up all the linkages, shock, fork, steering stem.
top up fresh coolant, gear oil, clean air filter, carb is all i recommend.
Posted: 03:14 pm Jan 16 2010
by brokemk3
juliend wrote:base gasket, head gasket, crank seals, case halves, intake manifold... Umm... that's all I can think of off the top of my head.
lmao i know right? just messin idc.
