Since I'm going to buy some hand guards soon I figure I will replace the handle bars while I'm at. The bike is new to me, 2004 200 which Ive ridden only once. I finally found a bud to ride with here in St. Louis area. Anyway, I'd like to eventually put on USD forks which I have, 96 KX 500 forks.
Would it make more sense to buy lower bars, say 2.7" high and add a bar riser to lift the bar 1". Would this allow more room for the USD fork to slide beyond the top of the triple tree if needed and give better access to fork adjusters and air bleeders?
OR
Buy a higher bar such as a CR High bend, 3.7" high. Is there plenty of room between the bars and the top of each to access the adjusters and air bleeders with this setup?
Would a steering damper play nice with each of these configurations?
Higher Bars or Risers?
- Has thanked: 5 times
- Been thanked: 12 times
You can only slide the tubes up so far in the clamps before you are out of the clamping area of the tube. Much more than about 1/2" is pushing the limit on most forks. I wouldn't use that as a reason to use risers over taller bars, because you aren't gonna get much more out of them anyway.
That said, have you checked out rox risers yet? Pretty sweet.
http://www.roxspeedfx.com/cgi-bin/cart/ ... cat_id=268
Those are COOL. Someone here installed some recently. Wibbly maybe? My CR high bend tusk 1 1/8th bars will be here tomorrow. I'll let you know what I think of them.
- jr111
- Varmint
I think the risers would be a better choice. I pushed the forks up to where the geometry of the bike remained stock. With the risers I was still able to get to the clickers and bleed screws.
See this thread: http://kdxrider.net/forums/viewtopic.php?t=8170
[/quote]
I don't think a higher bend would get better access because I believe the "bend" occurs after the fork tops.
OR Buy a higher bar such as a CR High bend, 3.7" high. Is there plenty of room between the bars and the top of each to access the adjusters and air bleeders with this setup?
I was looking to do a submount and this is a little tricky. After my research it was determined that only a weld on tower option is available. The KDX head clamp option is no longer available.Would a steering damper play nice with each of these configurations?
