fork springs on a 2004 220
Posted: 04:28 pm Dec 27 2009
by coffekid
Hey guys, this is my first post. I just got a 2004 220. I haven't been on a bike in almost 20 years. I keep reading that the forks are the weak link on this bike. I was wondering what the best spring was for my weight and riding style. I am 200# and will mainly ride trail/ singletrack. What is the best spring for the money and any recommendations on fork oil would be good also. I think yall have an awesome website, thanks for any help you can give me...
Posted: 10:48 pm Dec 27 2009
by bronco95tgp
Coffekid go to
http://www.racetech.com Under the 'search' tab, go to 'spring rate search'
Use that spring rate calculator to see what springs you need, it gives you options to include weight and terrain variables.
Racetech springs are $109.99 a pair and they come with at least one sticker!
I think that is the most common site used. Good luck welcome to the site.
Posted: 09:14 am Dec 28 2009
by coffekid
Thanks bronco, that was good info!
Posted: 09:47 am Dec 28 2009
by zomby woof
I would do the research, but ride it first before you buy anything.
Posted: 02:42 pm Dec 28 2009
by KarlP
The stock forks are a bit undersprung on the stock KDX. At least mine were at 170 Lb.
Do a little search on XR400 springs. There are two OEM rates available and work well in the KDX.
I ended up at 7.5 wt oil, mixing 5 and 10 50/50.....Another search!
Posted: 02:44 pm Dec 28 2009
by Indawoods
Posted: 04:10 pm Dec 28 2009
by canyncarvr
The weak link in the 220 is the
PISTON!!!
If the bike has an OEM piston in it..change it first.
RaceTech's recommendations are generally on the 'high' side of things for woods/trail riding. If you're going to be an MX-jumper-guy, besides being dead doing that on a 220 so it won't matter, RT's recs are good.
The OEM spring length is around 470mm. There is a steel tube of a preload spacer in 'em about 90mm.
Some folks think a fork leg full of solid steel spacer is neat. I think it's stupid. Put
SPRING in there! Hence...the XR springs..which will generally run 530mm or so. Install them with something other than the OEM brain-dead 35mm preload.
You're better off with Honda springs..not springs FOR a Honda from some third party mfg.
Yep. Guarandamteed to be all IMO and worth every penny it cost!!
Posted: 07:27 pm Dec 28 2009
by zomby woof
He's right.
The fork pistons are a definite weak link. I would change them both right away
Posted: 07:45 pm Dec 28 2009
by canyncarvr
Better'n gettin' forked BY a piston.
..right away or later.
Posted: 10:05 pm Dec 28 2009
by coffekid
Frankenschwinn warned me about the top end. Good advice from all, thanks...
Posted: 01:04 pm Jan 04 2010
by river
canyncarvr wrote:I keep reading that the forks are the weak link on this bike.
PISTON!!!
Why Honda springs instead of PC or such? Probably won't have one for my 230#?
What do to about the poor piston?
Thanks....
Posted: 01:20 pm Jan 04 2010
by canyncarvr
Honda springs are hot wound. Most 3rd party springs are cold-wound. Some folks argue there isn't a difference. Suspension folks that I have asked about it..folks in the industry that I respect..their preference is hot-wound.
...if you can get 'em.
Re: 'What do to about the poor piston?'
Replace it.
Posted: 02:32 pm Jan 04 2010
by Mr. Wibbens
To each his own, I find RaceTech's recommendation to be spot on
Posted: 03:50 pm Jan 04 2010
by coffekid
Thanks for the info guys. I am ordering a wiseco piston this week and im going to play with the oil level then decide what springs I need. I would hate for the ol 220 to exprode. Any recommondations on tranny fluid?
Posted: 03:57 pm Jan 04 2010
by canyncarvr
Re: 'Any recommondations on tranny fluid?'
Are you just ACHIN' to cause trouble?
More of everybody's opinions..with no clear winner.
...except...everyone thinks
THEIR choice is the obvious (and probably ONLY) one.
The Kawi spec sheet lists 10w-30/40 SE grade motor oil. ANYthing that is listed as 'energy conserving' should not be used.
An oil specifically engineered for wet clutch use is good. The levels of zinc and phosphorus in 'new'er spec'd oils are very low..and wet clutches like that stuff.
I've used the spec'd oil..motor oil. I prefer a motorcycle-specific (
for wet clutch use) oil. That preference is based on....what? IMO, of course. The bike shifts better, shifts are consistent over the course of the oil's use...a couple-three rides.
Re: 'im going to play with the oil level...'
Good. You will find quite a large difference from changing the 'amount' of air-shock in the front forks. I don't know what going through that process with a clearly wrong spring will accmplish. With some 530mm springs suited for your weight/riding style and a 3-8mm preload, everything is going to be different.
