I wiped the mating surface with a rag..gave it a 1/4 turn on a piece of 400 to get the gasket sealant loose..but that's it.
(Where it's dark is where it's shiny)
Kind of a funny pattern, ain't it?
It's as raised there as any other place there is a bead to the gasket..around coolant orifices and the cylinder itself. It does look to have more of a ridge to it due to the carbon that's in it. Certainly it looks 'deeper' than, say, 180º across the hole.Gasket picture (third from top) - between arrow and x and between coolant hole and cylinder - does the gasket surface appear to be raised?
The cylinder has no raised sealing surface no where. It's flat. The difference in appearance in the 12-8 of the cylinder matches the gasket in the same area..more a matter of lighting and shadow in the pic. You may be thinking of some 'race ready' kind'a machine?Your cylinder picture - Does the KDX cylinder really only have an raised sealing surface from 12 o'clock to 8:30 in your picture or is that some sort of illusion I'm seeing?
I'm wondering about the latter of those two. I have been losing coolant..although it seems to drop a couple ounces and stay there. I've figured there's an 'air shock' effect in the cooling system that makes that happen..just like an 'air shock' in the forks (not that a fork air shock makes a funny burn pattern on a piston).Yep a funny pattern on the piston - I'm betting your thinking your bike is running a little rich on the side of the piston which is clean: However your piston could also be "cleaned" as a result of coolant entering the combustion chamber.
Yep....and...don't know. There's snow and ice everywhere 'round here..not too conducive to riding. Heck...I doubt I could get up the hill to the staging area. Rode it around the house a bit..took off the rad cap. It had pressure. The coolant (50/50) looked pretty frothy. Didn't like that. Maybe after having been drained it's got some air pockets to work out. I did burp it at the head snorkle before I started it.Have you stitched it back up yet? Still acting up?
Well now. Wouldn't that be good to know!Was that gasket ever re-used?
That would certainly be the smart thing to do....and I should at least do that.RBD wrote:You are going to pull the cylinder and at least re-ring it, aren't you?
Ron
