Bike Performing Differently
Byte
Post by Byte »
Hi Guys.
My KDX220 is performing differently since i put the FRF exhaust spacer / Ring inside.
Oh - I've also topped up my transmission oil.
It feels like it is holding back and straining itself in first/second gear.
I am unable to get into third atm due to the very tight terrain on my property.
I don't whetehr this is due to the ring or something else...
Help?
Byte
Tedh98
Re: Bike Performing Differently
Post by Tedh98 »
Byte wrote: I don't whetehr this is due to the ring or something else...
Remove the ring and see how it runs.
Byte
Post by Byte »
woudl i need to make any jettign chages or anything else to compensate fo rthe addition of the ring?
Byte
Post by Byte »
Assuming I did not have that ring in there, and still had this "pulling back" sensation, what owuld cause this?
Byte
fuzzy
Post by fuzzy »
Checked your spark plug for fouling?
Has thanked: 5 times
Been thanked: 12 times
Byte wrote:Assuming I did not have that ring in there, and still had this "pulling back" sensation, what owuld cause this?
Byte
Let's not "assume" anything please. That gets nobody anywhere. Take the spacer out and test it again. Bet you can do it in less time than you have spent on this thread. I had one in my 200, hated it. Felt like it took WAY to much top end from the bike, and added only a little to the low end. Waste of money IMO, but I think I told you that already......
J.
That is the general concensus. Jetting it correctly will take you further than anything else. Concentrate on that.
Byte
Post by Byte »
thanks, i will look into all these options..
i guess to describe it better would be to say it is labouring.
would putting too much oil in the transmission cause this effect?
byte
barryadam
Post by barryadam »
Did your trans oil go into the exhaust?
Plugged up exhaust has those symptoms.
When's the last time you re-packed?
Check pipe AND muffler.
"I hate heli-coils. They are like hospice for motorcycle parts."- BDI
Byte
Post by Byte »
Thanks. How do you tell if trans oil wen tinto exahust?
Repacked - unknown when it was done (if at all).
I will check pipe and muffler.
Byte
Tedh98
Post by Tedh98 »
Byte wrote:Thanks. How do you tell if trans oil wen tinto exahust?
Byte
Just remove the spacer!!
Shouldn't take more than 10-15 minutes at the most. No need to start chasing after other things.
If you put too much oil into the tranny, yes, it can cause some extra drag. Probably not enough to notice unless you filled it up to the top of the fill hole or something silly like that...
Green Hornet
Post by Green Hornet »
I find it hard to believe the Torque Spacer would cause this.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
Byte
Post by Byte »
Perhaps this torque spacer is doing what it intended - creating more low end torque and it is this increased torque I am noticing that is different...????
Byte
When you eliminate the impossible, whatever remains, however improbable, must be the answer.
Take the 15 minutes to pull the spacer out and give it another run. Why are you so reluctant to do this???
