fredette chain guide
Ok so when my hub and sprocket blew up it also damaged my stock chain guide..i could probably bend it back but...if i get the fredette can i finally run a o-ring chain without it rubbing?
..which means there are NO marks on the outside of side plates..and the master link clip has NO wear on it?NewMexico505 wrote:I have a Fredette chain guide and run a X-ring chain, no problems.
The question was:
Hello?????
There was never a response to the the question of the answer than wasn't an answer.
Re: 'can i finally run a o-ring chain without it rubbing?'
..and will the FRP chain guide prevent that.
Doubt it.
I've not seen a bike (or quad) yet that didn't 'rub' on the outer 'edge' of the side links AND on the master clip.
I have an aftermarket chain guide. Got it 'cuz it's easier to change blocks in it. It's plenty wide..width isn't the issue when it comes to rubbing.
Glad to to be proven incorrect, but I'll bet the answer to the OP's question is 'No.'...not '..no problems.'
Doubt it.
Think about it, what does a guide realy mean. A guide in most sense of the word is there to keep you going in the right direction. A tour guide will do this by waving his hands and showing the right direction. Since a chain guide does not have hands
it does so by rubbing to keep the chain from falling off the sproket.
So the answer to the question "if i get the fredette can i finally run a o-ring chain without it rubbing? " is no it definatly should rub because thats the point. They wouldn't go so far out of their way to sell additional wear blocks if it wasn't supposed to rub.
I got a question though: how much rubbing is too much.
Gallery!
Gallery!
When the pins are gone.
I watch the clip. When it's thin enough to see though...I replace it.
Of course, the check for 'too thin yet?' is usually at least one unit of time after it's fallen off.
So..that's the rub, 'eh?
Well, yeah. I assumed that part. Hhhmmmm ....a chain guide that didn't touch (rub) the chain. That would be a good invention.
I ass uumed the question had to to with the side plates and link clip.
Still..you're right. A chain guide with no rub would be no guide a'tall.
Good point!
How much rubbing is too much?
I'd say when the chain starts to chafe...that's too much rubbing.
..and when the screws holding the bottom block in get close to being exposed..THAT'S too much rubbing, too.
Good point!
That would be wear wich would be a consequence of rubbing. I know how much wear is too much but the answer I was looking to get was how much rubbing is to be tolerated to prevent excessive wear.canyncarvr wrote:
BTW dont mind me, i'm on vacation and have nothing better to do than be a smartass
Gallery!
Gallery!
As much as a chain guide gets you?...how much rubbing is to be tolerated..
Never settle for less!
