What the best tire for me?
Hey guy. Ok so I was running a bit smaller tire than stock ( 90) and I bent my back rim. I am wondering what's the best tire/tire size for me. I ride in mid Louisiana. So tight woods and some atv trails. There are some mud holes and sand. But mostly solid dirt. One big thing is roots!! I have popped a tire already too. Not slimmy wet roots, hard big roots! And lots of them. I need a very tough tire. Any help?
09 KTM 250 XC-W
2005 KX-DX Hybrid
03 Ozark (under construction)
1978 Honda NC50 (under construction)
2005 KX-DX Hybrid
- Has thanked: 6 times
- Been thanked: 10 times
My choice, Maxxis IT. It seems to work pretty good in just about any terrain I run in to and is definately a "tough" tire.
The stock rims bend..running an '80' or a '90'. Run it at 15psi (too high!)...they'll still bend.
A '90' is smaller than stock..but you won't find a lot of commonly used tires that come in a 100/100 size. Besides..two differently branded tires with the same numbers on the side will likely NOT be the same size.
I'm saying: The OEM rim getting bent is not an indication of running the wrong tire.
What you need is a Michelin tube-type radial trials tire @ 8psi.
- Mr. Wibbens
They look kinda dorky but it sure hooks up
I haven't ridden it in sand. Others that have say: It works better'n a knobby', and, 'It's not as good as a knobby'.
So..there you have THAT decided for 'ya.
In deep mud (over the tire mud) it's reportedly not up to a knobby. Dunno 'bout that either. I had it some clay/mud last weekend and it worked every bit as well as last time I had a knobby in that situation.
..which is to say..neither tire worked for diddle.
Sorry. You can't have it all. You will not find the traction of a 756 with the wear of a VE33.
From my last four rides on the Michelin, I'm sold. Yep...that's a biased personal point of view. I've gone through 2-3 tires a year for the past ten years..the Michelin is the best..hands down.
Will it be as wonderful for you?
I have no idea.
The Michelin cost me about $7 more than the tire I would usually get (M5B). If I'd gotten the tubeless variety (at about 2X the tube-type cost) I might have thought a little slower about it.
You've got nothing to lose. You will either find the tire to suit you just fine, in which case you will hve learned something. Or, you will find it's NOT just fine..in which case you will have learned something.
Do as you wish. You asked a question, I answered it. IMO and all that.
Cheers!
I have no idea.
Cheers!
- Mr. Wibbens
What's your braking like with that thing?
It seems to have a lot of grip going up hill but I wonder what it does going down
I love the M5B for that. It takes a lot to slow my extra momentum
Hard to say on the braking part. Riding conditions have been lousy for braking in general, but the trials tire has done OK. What it would do in dry/crumbly conditions..don't know about that.
One thing it DOESN'T do real well is brake-steer. With a knobby..lean into a turn, hit the brakes to skid the back end around to line up in the direction you want to go..fine. The trials tends more to brake in the direction of travel and NOT let the back slip 'around'.
Still, nothing that isn't more than compensated for in other areas.
It's not like the S12 I had..hit the brakes..skid the back tire...speed up!
I haven't used a trials tire - yet. I have seen guys with them and they do hook up well.
I've had good luck with the Dunlop D952. I've used them on my KLX250S for some time now. I have one on the front of the KDX, still running a crappy 4.10-18 Cheng Shin C755 on the back though. I'll replace it with a 952 soon. Not sure if I will run a 110/90 or a 120/90 on the KDX. I have a 120 on the KLX and it works great on that bike but looks huge compared to the 4.10 tire on the KDX now. I think putting a huge heavy tire on a bike is not always the best idea, both from an engine/gearing standpoint and a suspension standpoint (more unsprung weight for the shock to deal with isn't good).
Mike S.
'98 KDX200
'07 KLX250S
'06 KLR650
'93 ST1100
'98 KDX200
'07 KLX250S
'06 KLR650
'93 ST1100
I have heard that these trials tires outlast a standard nobby tire by quite a few hours also. Sidewall flex is also supposed to be superior to anything going, may be why its hard to slide around? They do look sissy but one or two more rides on my Maxxis IT and I'm getting a trials.
its a '04 KDX 220 cadillac
- Mr. Wibbens
A trials tire sounds great for the terrain I ride in but I can't use one. See, I do some pretty high speed stuff (up to 55mph) and some pavement so no trials tire for me.
