stock light wiring harness on a '00 KDX200
Posted: 05:12 pm Oct 11 2009
I have said bike, it came with the dual DHH light set up from Acerbis. It uses 2 20watt tungsten halogen bulbs. It works really weel except for the fact if it gets cold or wet outside and I have the lights on it forms condensation on the inside of the bulbs. Was thinking about going back to stock light set up UFO sells a light that is equivalent to stock (35watt) I need to know what the stock light wire harness looks like. I just have 2 wires feeding power to the lights right now, The oem fische shows 3 wires for the light harness. Is the 3rd a ground wire or something? I would like to keep the light setup I have now, but with winter coming, I feel I will be replacing lights all the time. I get the bulbs at Home Depot as they are a house light. Maybe that's the problem right there. Maybe they are just for interior use only. I'm sure I have the stock lighting coil in bike hence the 2 20watters that were in there before. The stock lighting coil only puts out 35 watts, right? I have no tail light either. Any ideas as to how I can cure the condensation problem? If not, I will be going back to a oem style light.
Thanks in advance
Little Jeff
Thanks in advance
Little Jeff
