Heads up- RMATV sprocket clearance
Posted: 07:47 am Sep 16 2009
by porterdog
Just got an email from RMATV- they're blowing out 49t rear alu sprockets for our KDXs for $16.75.
Click here
Posted: 10:58 am Sep 16 2009
by Colorado Mike
huh, thanks dawg. I wonder if I buys me one, and if I gots a 12 or 13 toof CS sprocket if I'll be needing 110 links instead of my stockly 108? and if there would be a clearance prob on the guide.
Posted: 03:45 pm Sep 20 2009
by jbowens2401
porterdog,
Thanks for the heads up...I just bought one using the 10% off discount code (96639) and got it for 15.07 plus the 7 dollar shipping charge.
Colorado Mike,
Your stock guide should work fine with the 49t rear. As for the 108 link chain, it will work if your chain is strecthed.
Posted: 06:50 pm Sep 20 2009
by Indawoods
Kinda pointless replacing the sprockets without a chain change also.
Posted: 07:23 pm Sep 20 2009
by MXOldtimer
Indawoods wrote:Kinda pointless replacing the sprockets without a chain change also.
Agreed. A worn chain will wear the teeth quickly.
If you chain is fairly new than you can change with no problem. We would change our rear sprocket (teeth #) all the time going from track to track on the same chain. I would lay my chain on it's side and pick it up to see how limp it was. A brand new chain you'll get a 8-12" arch while a worn chain will arch a half circle.
Posted: 07:49 pm Sep 20 2009
by jbowens2401
I agree also...my chain has about 100 miles on it,so I should be good to go. My sprockets are good too...I just couldn't pass up on the deal.
Posted: 08:38 pm Sep 20 2009
by canyncarvr
Only read anecdotally many times, but a 49T is supposed to fit fine with OEM guides, a 108L and either a 12/13..but a 50T takes 110L.
Don't matter...buy a 110L and take off a couple if'n it's not right.
Maybe what you
really need is 109T.
Posted: 09:06 am Sep 21 2009
by Colorado Mike
I've tried odd numbered link configurations a long time ago and was not happy with them. Perhaps they were developed for folks in the southern hemishere, but they just don't work well for me.
