I was recently able to get my hands on a 96 KX500 forks with triple tree and the front wheel/tire/disc, however it will not be coming with the front axle. I have not received the items yet so I don't know what other parts the front tire will have with it such as bearings, seals etc.
I've been looking on ebay for the front axle but I am unsure what axles are compatible. I've looked on the kawasaki site under parts diagrams, different years, 125s, 250s, 500s and they all seem to have the same part number 41068. What axle will be compatible with the 96 KX500 front wheel or where can I look to figure this out?
This is what I can find on ebay
04' Kawasaki KX250 KX-250 / FRONT WHEEL AXLE W/SPACERS
92' Kawasaki KX500 KX-500 / FRONT WHEEL AXLE W/ SPACERS
1999 KAWASAKI KX 125 FRONT AXLE & NUT & WHEEL SPACERS
00 Kawasaki KX250 KX 250 Front Rear Axle
1999 Kawasaki KX250 KX 250 Front Axle & Nut
KAWASAKI KX250F KX450F KX KX125 KX250 FRONT AXLE AXEL
92 KX125 KX 125 250 500 Front Axle Axel & Spacers
KAWASAKI KX125 KX 250 FRONT AXLE KX 125 KX250 1999-2002
2007 KAWASAKI KX125 KX250 KX 125 250 F WHEEL AXLE AXEL
What front axle will work with 96 KX500
- Has thanked: 5 times
- Been thanked: 12 times
A 125 front axle probably will not work, but a 250 might. Then again, it might not. Best bet would be to check part numbers through a parts fiche and see which ones are the same part number. You have a good starting point by means of a list of what is readily available to you. So you can check the fiche for that bike as compared to the fiche for a 96 KX500 and see what does/doesn't match.
servicehonda is a good resource for such an effort...
- kawagumby
I bought a 98 KX125 wheel for a spare. It came with the axle and it is identical, spacers and all, to an 03 KX500 axle. So that era 125 wheels/axles will fit nicely with kx500 forks. 250 axles will work also from that era, but the spacers are different (I owned an 01 KX250 at the time I did a USD conversion using using 03 KX500 forks).
