Just adjusted my shock and got the sag correct - had to add just a little preload. Took it out riding and noticed that now the rear end is bouncing around when decelerating in bumps. It was not doing this before I added the preload. My question is - should I loosen I just loosen it up again or can the clickers fix this. If the clickers are the answer - is it the upper or lower and which direction should I go?
Sorry about the newb question, but I know very little about adjusting suspension.
Thanks
Shock sag and clickers
Anytime!
