stuck clutch
Posted: 10:32 am Aug 29 2009
by 3dhunt
what causes a clutch to stick when you put it in gear for the first time of the day? I run thin oil and always let things warm up, but i have to ride a ways with the clutch in before it breaks loose. Fine from then on. What is the fix for this problem? thanks 3d
Posted: 11:06 am Aug 29 2009
by Indawoods
All the Triumph motorcycles I have ever owned had this same problem. I would just pull the clutch in and kick the bike in the off position until it broke free. Dry plates is what causes it.
Posted: 11:30 am Aug 29 2009
by 3dhunt
does replacing plates correct or change anything?
Posted: 11:50 am Aug 29 2009
by Indawoods
If you take the plates out... check the tolerence, soak in oil overnight and put them back in it may help....
