Motion Pro fork bleeders
Anyone got any feedback on the fork bleeders? I was considering buying some. I have read that Alot of guys say use them often, but don't you need to have the front wheel off the ground before you do the deed? Does everyone get the front end of their bike off the ground before bleeding them? I'm thinking if I have to go through the trouble to put the bike on the stand why not just use a screwdriver, except for wearing out the threads. Thoughts, comments, derrogatory remarks?
2001 KDX 200
Yep... in the "product review" section. They don't have to be off the ground... just pull up until fully extended... and push... done deal!
- skipro3
You're too funny Trev!
I like my bleeders but do read the review, there are things to consider before just sticking them on the bike to be aware of. Someone really needs to make a schreider valve kit that is rugged enough. I think there is, just that it's about $100 and obviously rediculous price. If I find the source, I'll post in the review section.
I've had 'em for awhile..and I haven't even read the review yet!! I probably have erred somehow....
But I sure like mine (and they are MotionPro). I used to think the handling problems I had late in a ride were my fault..getting tired, not paying attention..something.
But, no. It was pressure buildup in the forks.
I pop the bleeders several times a ride. Sometimes I pull up on the forks, sometimes I don't. You will find that you can vary your fork action by changing the air-shock IN them. Sometimes I push down on the forks a tad and then bleed 'em. Kind of depends.
Oh..and they're good for letting unwanted pressure off when you strap your bike in for the ride to/from, too!
BTW..I got the no-thread no-worries screw-'em-in type. If you drill and tap, they will be a bit shorter.
Now I guess I have to go read about all the bad things about 'em...........
- skipro3
They wouldn't be too hard to break off. Mine sit too close to my inside lever guard mount to suit me. A good wreck in all the wrong places would break it off.
...I don't want to think about it. I looked for my oem screws..didn't find 'em, haven't been to the hardware store to get new ones. I'm riding on borrowed time!!!
They are great handling improvement items!
- skipro3
CC, see if the KX ones are the same size. Then use those for backups. I have a set of screw plugs in my fanny pack now.
To anyone getting fork bleeders: save the stock screws and keep them in the fanny pack in the event you have troubles.
