Flywheel nut torque
128racecar
Flywheel nut torque
Post by 128racecar »
Anyone know off the the top of their head what the torque spec is for my flywheel nut?
Thanks,
Marc in Indy
Newbie 2003 KDX 220
Marc in Indy
jaydollar
Post by jaydollar »
not to tight and not to loose !!!seriosly, 47 ft. lbs. or 64 N-m if you are metric savvy.use a car oil filter wrench with some sandpaper around it to keep it from spinning.if the top end is off, use a con rod stopper.J$ out.
1999 kdx 220
rb carb, rb head pump gas mod. 607 reeds, airbox lid drilled
fmf torque pipe
fmf turbine core Q
trail tech endurance computer
13/49 gear
Not to be a nit about it..but spec is 88 nano metres...9.0 killergrams per metric or, in the real world, 65ft/lbs (which happens to equate exactly to three whacks of my impact gun, set to '3' @ 120psi).
Figures from the book...pg. 5-14 CLUTCH section.
...and CHECK to ensure the key stayed put after you put the rotor back on. Stick a piece of wire or straightened paper clip in the slot of the crank..make sure it stops when it hits the key. They slip out easily.
The clutch spring bolts? Only 78 INCH lbs.
Cheers!
128racecar
jaydollar wrote:use a car oil filter wrench with some sandpaper around the flywheel to keep it from spinning.
Brilliant!!! This trick worked better than "in gear/rag in sprocket/up against a wall with brakes on"
Thanks,
Marc in Indy
2003 KDX 220R
Marc in Indy
jaydollar
Post by jaydollar »
canyncarvr...i hate to be a double nit, but i believe 128racecar asked for "flywheel nut" torque,not"clutch hub nut" torque.that spec IS in 5-14 section in the book.the flywheel nut torque is in section 14-10 top left of page.i'll take a crown and coke on that one !!!J$p.s. how far is it to jefferson from dallas anyway?
1999 kdx 220
fmf torque pipe
fmf turbine core Q
13/49 gear
Criminy...you are correct. I am not.
But...you knew that already.
Yep..I switched to the other side of the engine.
C&C it is..but that's FOB SOJ!
How far from Dallas?
Mapquest sez:
Starting Location: Dallas
Ending Location: Rogue River
Time: 3 hours 46 minutes
Distance: 218.34 miles
Map here.
:mrgreen:
Thanks for the double nit. Guess that makes you owed a double C&C, 'eh?
:oops:
128racecar
Oh no, I overtorqued and stripped out the treads!!! Just kidding!
Great ride today on my new (to me) bike. What a great trail bike.
Marc in Indy
2003 KDX 220R
Marc in Indy
jaydollar
Post by jaydollar »
enjoy and post some pics and info on the bike.canyncarvr,at three hours and 220 miles i thought about taking you up on the double c&c. i thought rogue river was in louisiana at that distance so i looked at the map link you posted.but i am in dallas, texas, not oregon..thats 30 hours and 2000 miles.:shock: ill post you a pick of me drinking one instead and you do the same.the farthest east i have been is lordsburg new mexico.ride safe.J$
1999 kdx 220
fmf torque pipe
fmf turbine core Q
13/49 gear
But...you said '..how far from...dallas....'
I thought the little 'd' was significant?
Re: 'farthest east i have been is lordsburg new mexico..'
I'll take that as 'farthest west.
In which case, c'mon over! It's time to see some country!! Find another rider to split it with..that's only 15 hours each!
Simple.
Probably a good idea to wait 'til fire season is over. The woods are closed out here.
clescault
Flywheel nut torque
Post by clescault »
I am new, and have only rode for about year, I have a 1998 KDX220, is the flywheel nut the one that is on the side of the friction plates? I assume so since you put the specifications for the clutch spring bolts, but just want to be sure, and will the numbers be the same for my 1998 as the 03 talked about in this post?
Flywheel nut torque
clescault wrote:I am new, and have only rode for about year, I have a 1998 KDX220, is the flywheel nut the one that is on the side of the friction plates? I assume so since you put the specifications for the clutch spring bolts, but just want to be sure, and will the numbers be the same for my 1998 as the 03 talked about in this post?
CC was incorrect with his spec. He was referring to the clutch hub nut. The flywheel nut is on the left side of the bike under the plastic cover. The clutch hub nut will be on the right side of the bike under the clutch cover. (The cover with the clutch arm in it).
Any 95+ will have the same specs for torques. Might want to look into getting a manual tho. :wink:
clescault
Re: Flywheel nut torque
Post by clescault »
Yea..i just spent all my christmas money on clutch plates, a new clutch hub, and a new shift lever. So trying to rebound from all the money i spent haha!
Do I understand correctly that the complaint is 65ft/lbs is incorrect for the big clutch nut?
If you want to pick the nit, how about telling me I'm on the wrong side of the damn bike.
Oh...wait. That already happened.....THREE YEARS AGO!!!
But, the 65ft/lb spec listed for the stated fastener is correct.
You're welcome.
canyncarvr wrote:Do I understand correctly that the complaint is 65ft/lbs is incorrect for the big clutch nut?
No
somebody wrote: CC was incorrect with his spec.
Good. Glad that got sorted out!
