Boo Boo on my Rim
Posted: 08:41 pm Jun 29 2009
by Varmint
:mrgreen:
Looks like I hit something pretty sharp on the trail. Cut the tire and bumped the wheel in a bit. Tire is still on well and the tube never popped. I've read other post on here to just leave the rim alone; don't try-an' bash it straight.
What do you think?
(Never-u-mind about the dry chain and beer cans!)
Posted: 01:51 am Jun 30 2009
by shanana
If you were or are planning run a tubeliss system then I would propose you take the rim to the specialists that would be able to fix it in such a way that nobody will ever know that it was damaged. If not and you are using heavy duty tubes with slime then leave it as is. :wink:
Posted: 08:22 am Jun 30 2009
by skipro3
Using a block of wood and a hammer, work that dent slowly and you'll be fine.
Posted: 08:35 am Jun 30 2009
by Varmint
Happy 4000th post skippro!
Posted: 11:53 am Jun 30 2009
by canyncarvr
skipro3 wrote:Using a block of wood and a hammer, work that dent slowly and you'll be fine.
That'll take care of a lot of it. No 'looks like new' going to happen with a sledge and banging on it..but it can look better.
I wouldn't worry about it. I don't...and my rim has at least a few dings that big. Some I've pounded on, some I haven't.
Mr. Ski: Please do expand on the 'wood-n-hammer' approach?
BTW...what's with the no chain maintenance...and all those beer cans!!! :wink:
Posted: 12:59 pm Jun 30 2009
by jaydollar
i had one of those dents on my front wheel. i loosened the spokes in the area of the dent first,and then whacked it with a brass hammer.not perfect,but a lot better than it was.used wheel /mag polish to buff the brass marks off.j$
Posted: 02:13 pm Jun 30 2009
by skipro3
I've used a 2x2 shaped a bit like the rim, then tapped on it with a hammer. It doesn't take a hard or heavy hand though, so be easy and work that dent out. I didn't loosen the spokes when I did mine. I figured that they were correct length before the dent, then they would be pretty good at keeping me from making a mistake with my tapping.
Posted: 03:06 pm Jun 30 2009
by canyncarvr
For some reason I had the idea you used the wood UNDER the rim edge..as a backing.
What's a 'hammer'? 16oz one-each? 22oz framer?
I've used a 2 1/2# sledge. No wailing on it, just using the mass of the sledge, not speed and force with a lighter tool. It worked purty good.
And..yeah...I didn't loosen my spokes, either. Figured the same thing..didn't want the drop center of the rim to change, although I suppose pounding on the rim might tend to make the spokes 'long' anyway.
Never seen a 2 1/2# brass sledge, although that would prolly work good!
Posted: 02:23 am Jul 01 2009
by skipro3
I left the inflated tire on for the backing.
BTW Sears has that 2.5lb brass hammer for ya!
http://www.sears.com/shc/s/p_10153_1260 ... 921x00003b
