Considering a 2000 KDX200 for my first dirt bike??
I've owned a street bike for years but got my first taste of dirt a couple of weeks ago on a buddy's rm250. We rode a combination of trails & a little mx track. His 250 was a little too explosive to me for a new rider. I've found a 2000 KDX200 for around 1400 on local craigslist. Can this bike handle some light jumping along with trail riding or is it a pure trail bike? Would this be a good first bike? Is this year model known for any problems? I was originally looking for a 2 stroke 125cc mx bike. I can also get an 02 YZ125 for around the same price. Just not sure which would be the best first bike.
Thanks in advance for ANY tips / advice!
It will handle anything but all out MX racing. No problems associated with this model, just spring the front end for your weight and grease the bearings real well when you get it. The bikes are bulletproof!
Top of the page and to the right for a manual... KDX MANUAL ONLINE
Wheel bearings, swingarm bearings, shock link bearings and steering head bearings all need maintenance.
Just depends on what you weigh for the spring rate for the forks. The stock springs are only good to like 150 lbs.
I'm 175. Is there an easy way to tell if the stock springs have been changed to handle someone my size? Or is it just a matter of adjusting the springs?
I clicked on the link for the manual...looks like an annual subscription type thing?? Is there not somewhere to either get it for free or pay and download the manual?
They have a lifetime subscription that is cheaper than the factory manual.
Or, you could order one from Ma Kaw or check eBay for one.
You will need new springs but I would wait until you have a little seat time on it before you worry about it. Just don't take any huge jumps or press it's limitations in stock form. People have replacement springs for sale on here from time to time too.
Thanks for all your help. Here's the bike I'm looking at. http://dallas.craigslist.org/ftw/mcy/1222942295.html Let me know your thoughts!
thanks again.
Greg
thanks again.
Greg
Nice and clean... that's a good sign. Always look around the frame area by the foot pegs... that is a good indicator on how much the bike has been ridden. It looks like it still has a great deal of paint there....
Grab the rear tire and try to move it side to side... that will give you an indication on how good the bearings are. Check the sprocket for wear and bent teeth. Check the rear shock for oil running down the shaft or a wet bumper. Ask him how often he changes the clutch oil and what he uses. Check the air filter to see if it's clean and not ripped somewhere and see if it is sealed with grease around the seal.
That's a few things to check for... there are more but it's late... and I'm tired!
- Colorado Mike
Just be careful if you get the KDX. Before jumping anything big, get familiar with how different a KDX is. If the forks have never been touched, like Inda says the springs will be very soft. But also the fork oil they put in is horrible. This is easy to fix and plenty of threads on here tell you what to do. The stock forks can be made to work a lot better for under $100.
My son rides a 2005 YZ125 and loves it on the track, but on tight rocky trails he wants more torque. The KDX is much better there. When I ride his bike I'm amazed at how well it handles. It's way lighter and the suspension on the 2005 and up models is very nice. It would be nice to put a KDX motor in the YZ aluminum frame.
Anyway, you can't beat a KDX for a first bike, or even a 6th. just fix up the forks before you follow your friend over a big jump. Once you get better you can catch the fork fever and convert the front to KX forks.
- Colorado Mike
really, I think the KDX if you want to ride trails. If you really want to race, or ride on tracks mostly, then the YZ would be better, but keep in mind that the 125 will require more engine rebuilds. If you let the piston stay in there too long, it's going to blow. There's a big difference in how the motors are expected to be run between the two bikes. The YZ is a high RPM screamer, with a much less forgiving power band. My son has to slip the clutch and keep the rear spinning around corners in the woods, and that adds cost to the equation too, more tires, more clutch plates, etc.
The KDX would be better for a new guy that wants to ride trails. Cheaper to maintain too.
Both bikes would keep more or less the same value over a one year period. Buy the KDX first and after a year you can sell it at minimal cost if you realy want an MX bike. After a year a 125 may be too small for you any ways and you'd probably want a 250. I'm pretty sure a 125 will cost more to operate than the kdx. A beginer will be able to do mild MX with the KDX (if the susp. is set up right) but probably would have a real hard time doing trail riding with a YZ. Wich is why a KDX is such a good bike for beginers, not to mention way more reliable.
Gallery!
Gallery!
Design...
A Porshe 4 cylinder is not a Yugo 4 cylinder.....
Try getting 150K miles out of a Nascar V8 as compared to a regular V8.
Gallery!
Gallery!
