Will a 2002 Headlight plate work on a 2003?
John McIntosh
Post by John McIntosh »
I see there is a headlight number plate listed on ebay for a 1999-2002 KDX. Mine is a 2003. will it fit my bike? It looks to be the same but it's tough to tell. It looks like I might be able to get a good deal. Any info you can give would be appreciated.
Thanks,
Mack
Mack (Bel Air, Maryland)
Has thanked: 66 times
Been thanked: 20 times
Hi. You may want to check on the http://www.buykawasaki.com to be sure, but most parts are interchangeable or the exact same on the 1995 and newer KDX's.
John McIntosh
Thanks Jason.
No problem. That site has helped me a lot with matching up part numbers.
How about this:
From the link Jason noted (you bookmarked it, right?) an '00 shell PN is:
23005-5040-6W
The '03 PN is:
23005-5044-6w
Look at RonAyers.com to find the former is $73.76. the latter is $77.75
So...in some way MamaKaw says they are not the same part, but I bet it's an appearance issue, NOT a matter of fit.
Well..having absolutely no clue myself, I take that bet back!! :wink:
Let us know if it bolts-up good!
All the mounting brackets are the same, but the stickers are different. Since it comes with a different sticker, that is enough to throw off the part numbers. You may want to see if someone will look under their headlight and check for a molded part number. I don't know if the headlight shells have the number molded or not, but I remember seeing a fender like that, so maybe that would help.
