I thing i have a clutch problem :S
Posted: 01:36 pm Apr 21 2009
by kevfort19
hello, I wonder if this is normal when my bike is stop(engine not running) and put the first gear, I press the clutch and try to move the bike. The rear wheel is blocked as if I did not touch the clutch. Normaly on a car if you touch the clutch you can move the car, but on my bike if i'm in first or second ... the bike don't move even if i touch the clutch.
I want to precise that when i run with the bike , the gear are changing properly and all gos well
Posted: 01:40 pm Apr 21 2009
by Colorado Mike
That's a pretty common problem and is usually caused by the clutch basket fingers getting grooves worn in them. You can disassemble it and file them smooth again. supposedly switching to a Hinson clutch will improve things because the surface is harder. I never tried one though.
Posted: 07:12 pm Apr 21 2009
by canyncarvr
It happens with a brandy-new basket, too. Hinson, even (I have one). The notchy basket will give you trouble shifting when the engine is running.
Which is to say...it's normal for the KDX. Bikes that activate the clutch from the INside don't usually have that problem. The KDX activates from the OUTside.
That's why the KDX is harder to start in-gear than some other bikes, too.
If you have to move it in-dear, engine off, clutch pulled....rock it back and forth a time or two 'til you feel the plates break loose. It will still be hard to push around but the back tire won't be skidding along anyway.
...unless you're on something slippery..much...gravel over hardpan..something like that.
There are clutch anomalies that can make the stickage worse than it otherwise might be...but it's always going to be there to some extent.
Posted: 08:08 pm Apr 21 2009
by RBD
That is what neutral is for!
Ron
Posted: 10:25 pm Apr 21 2009
by jaydollar
amen ron,only takes a second,grab the front brake if you are on a hill!!! l
also what weight oil? viscosity and temp add up.
Posted: 12:34 am Apr 22 2009
by canyncarvr
A stalled bike, in gear, driven by the rear wheel...don't shift fer diddle. Put your not running bike in gear, pull the clutch, go downhill, just try to shift into neutral.
Point is..shifting into neutral is not always an option.
Point #2 is, the answer to keyfort's question is...'It's normal.'
For a KDX anyway.
Posted: 05:11 pm Apr 23 2009
by Colorado Mike
Hmm, aisle halve to try that. My bike shifts into newtral with the engine running when I least want it to. I never thought of shutting the engine off before each shift to ensure a neutral-free selection. Thanks for the tip!
Posted: 06:28 pm Apr 23 2009
by Green Hornet
Hinson clutch baskets are history. No where to be found..
Posted: 06:43 pm Apr 23 2009
by canyncarvr
Green Hornet wrote:Hinson clutch baskets are history. No where to be found..
Which is why I bought one before they went away.
No one said you could get 'em anymore..just that they work better.
Posted: 07:22 pm Apr 23 2009
by Indawoods
Work better than what? :hmm:
Posted: 10:46 am Apr 24 2009
by canyncarvr
Better than what was in the bike to start with..meaning the OEM basket.
