Clutch spring length
I took my clutch out yesterday and measured the spring length at 36.6mm. The limit is 37.2 and nominal is 38.7. The clutch isn't slipping at all and the only problem I have with it is there is some drag (but i filed off the rough edges on the basket so that might help and the spring that goes on the clutch hub had been installed upside down by previous owner, and the pushrod was shimmed incorrectly ). Should I still replace the springs? What kind of problems would weak springs cause besides slipping?
I've run into this.
Either the spec is wrong, or everyone making springs is wrong.
My OEM springs were all under limit. I ordered new OEM springs..they were under limit, too. I ordered some AFTERmarket springs..they were all over the place length-wise.
I wasn't looking to resolve any slippage issue...just doing basic maintenance on the bike.
You will not get rid of the drag problem. At least...if you do, please do share, as all KDXs do it..and the rate at WHICH they do it is worse'n most any other bike.
Re: 'What kind of problems would weak springs cause besides slipping?'
The main problem resultant from using those short springs (short doesn't mean weak 'natch) is maybe the headache you'll get worrying about it.
So....don't!
If you DO find one spring that is considerably different from the others, that I'd be more concerned about.
So....don't!
It's funny that the 95 KDX springs were considered weak and there was a service bulletin about it so I changed them. Really didn't need to but thought there may be an issue... there wasn't. I felt no difference at all....
