I'm in the middle of changing the rear spring but I can't get the existing spring off because the collar isn't turning much. The locking collar is free and moved up the shock out of the way. The adjusting collar (the one compressing the spring) is of course under pressure so I assumed it would be tough to turn. Forget about adjusting the collar on the bike, I can't move it when its sitting on the workbench! I've tried various spanner wrenches but they pop off long before any pressure is applied (yes, I oiled the collar and the spring face as well as cleaned the threads prior to this).
So, what's everyones' trick to moving the adjusting collar? Favorite tool?
How to remove shock collar? ARGH!!!
Threads are proly boogered..... mine was like that too.... a lot of determination is the only way I got mine off. and a few hours with a micro file afterwards....
>|QBB<[/url]
The threads are good. The locking collar spins real nice on them. Oh, the shock only has about 10 hours on it so it's clean. Here's a photo of it:Indawoods wrote:Threads are proly boogered..... mine was like that too.... a lot of determination is the only way I got mine off. and a few hours with a micro file afterwards....
Try turning the spring?
If that's don't do it... there is always spring compressors!
Thanks for the help, Indawoods. I was thinking of a spring compressor myself. Of all the tools I have I don't have a spring compressor. Ow! I'll bring it over to a buddy's shop and give that a whirl.Indawoods wrote:Try turning the spring?
What kind of spanner do you like to use when you adjust the shock when it's on the bike?
- fuzzy
Good heavens...
Put the thing in a soft-jawed vise...or use some leather scraps (maybe off an old set'a boots), soap up the bottom of the shock, grab aholt of the spring and just TURN the thing!!!
Vise doesn't have to be tight..you're just keeping it from turning is all...with the top of the shock in the vise, that's easy enough to do.
...like Inda said...but I don't see that it happened what with all the talk about wrenches and stuff.
