RACE SAG
Posted: 07:36 pm Mar 08 2009
by N8Strine
What is the proper race sag for the KDX 90-100mm? I know I read somewhere maybe 95mm since it doesn't have quite the travel as a KX. Also what is the right static sag in mm? Oh this is for Hare Scrambles.
Posted: 07:37 pm Mar 08 2009
by Indawoods
Posted: 08:00 pm Mar 08 2009
by N8Strine
Thanx.
Posted: 10:48 am Mar 09 2009
by canyncarvr
Step 4: 'Turn the preload nut to adjust rear spring....'
Seems much easier to me to turn the
spring, which will turn the nut. Some soapy water on the bottom of the spring helps (spring has to turn against its seat). Leather gloves help get a grip on the spring.
No need to bang on the spanner ring with a hammer.
Of course...do the spring adjustment with the suspension completely unloaded.
Seems worthwhile to me to experiment on either side of some starting point (like the 100mm listed in the above link). I found I preferred 100 to 95 and 105. 5mm is quite a large change..but I didn't care for the 'direction' the handling went
either direction from 100.
Check before every ride?
Doesn't everybody do that?
Posted: 11:11 am Mar 09 2009
by N8Strine
So are you running 95 or 100? Iam going to go with 95mm. Yea it is easier to just turn the spring and the spanner nut will turn with it.
Posted: 12:39 pm Mar 09 2009
by canyncarvr
Re: '..are you running 95 or 100?'
'I preferred 100 to 95 and 105'. 100 is my preference.
Maybe I should'a said, '..95 OR 105'.
4" to tell the exact trute about it.
