Ok, we are rebuilding the top end of this old KDX220B here (I'm in China). This model came with turn signals, speedometer, metal gas tank and oil injection (notice oil tank hiding behind the 199 rear side plate).
Question 1 - Crank shaft:
Found that the crankshaft's rod has some pretty obvious side to side play. We didn't measure it (not sure how), but it's very likely out of spec. What do you think?
video of crank play here: http://www.vimeo.com/3182701
Here are pictures showing the gap (red arrow) where I saw and felt the side to side play:
Now, do we need to replace the entire crankshaft assembly, (as in part numbers: 13037, 13037A and others?)
Or can we just buy something like this to solve the problem: (wiseco rod kit)
Question 2: Cylinder
This cylinder has seen better days... and probably zero mantainance in its lifetime. Replacement seems necessary. Question is, is this cylinder the same as other KDX220R models (like the KDX220-A4 KDX220R (1997))? The reason why I ask is because this model is the KDX220 oil injection (street legal) model sold in Japan. I don't know if the US ever got this one. The only parts diagrams I can find are for the KDX220R... If the cylinders from both engines are the same, then I could buy a KDX220R cylinder off ebay pretty easily and just bolt it on to my engine.
If pictures will help, please examine these of the cylinder off this bike:
Question 3: Another strange thing is this carb boot. The outside looks pretty bad, but the inside is still smooth, uncracked rubber. It was not "homemade" but just repaired the outside. Why does it have an intake port? Is that because of the oil injection system? Anyway, here it is:
Question 4: Oil Injection system
Here is the tank (been repaired). Just below the tank you can see the cool fold down aluminum footpeg for a passenger!
This is the oil injection system in case you're interested.
Since I'll use this as an offroad only bike, I'm thinking of just mixing gas and not using the oil injection system. Pro's and Con's?
Based on what I've read on this site, Wiseco pistons are the only way to go.Most importantly now though is securing the correct cylinder and rods/crankshaft. Thank you for any comments you guys have.
Chris in Sichuan
