What has anyone found that works good for proper jetting a 200 and a 220 at 700 Ft. ? Airbox top 3/4's removed and FMF pipe , Frederette torque ring and aftermarket silencer.
Idle air screw-
Low speed Jet-
Main Jet -
Needle position-
Rough Jettings numbers vs. stock
Air temp? Winter air requires fatter jetting.... a 155 main and a 45 or 48 pilot should work on the 200... and clip in the middle for the needle.
There is no "stock" jetting from what I can tell. It depends on the dealer and what they put on when they prep the bike. I assume they get a jet pak and use that.
"A 2005 220 with 33mm carb , Pilot jet #42 , Main jet #145"
That is how my '02 220 came stock.
I think I ended up 140/38 with a shiny pipe and 1/2 the airbox lid cut out.
You'll have to work on your own jetting; mine is specific to my bike, location, temp and riding style and NOT a recommendation as to what you should run
I'm not being a butt. The stock settings will run the bike, a couple of hours of carefull jetting and air screw changes will get it running nice and crisp
When Inda said 'There is no 'stock' jetting...' I believe he was referring to jetting a stock bike to a definite jet-set, NOT what 'comes with'.
The 200/220 numbers you posted are good for all 'H' model 200s and all 'A' model 220s (as far as I know, no warranties expressed or implied).
Certainly (as Inda said) a KDX could have rolled out the showroom floor with something different from OEM due to dealer changes.
- Mr. Wibbens
Re: Rough Jettings numbers vs. stock
A lot of this info might be found in the " Members Bike Profiles" section on this siteCurious George wrote:What has anyone found that works good for proper jetting a 200 and a 220 at 700 Ft. ? Airbox top 3/4's removed and FMF pipe , Frederette torque ring and aftermarket silencer.
Idle air screw-
Low speed Jet-
Main Jet -
Needle position-
