02 kx triple clamps
Posted: 01:18 am Jan 16 2009
by muddertrucker
I just bought a set of 02 forks to replace my 97's. I'm pretty sure I read here that they would not fit my existing clamps (97). When looking on ebay it seems clamps from 02 are different than all other years. I've seen that clamps from 99 to 01 are the same and 03 to 05 but nothing for 02. Can someone confirm this for me?
Posted: 01:17 pm Jan 17 2009
by skipro3
'02 forks are 2mm larger diameter than '99-'01
Posted: 05:20 pm Jan 17 2009
by it175
Ski is right on. I have 02 forks in a 04 clamp.
Posted: 07:27 am Jan 18 2009
by muddertrucker
skipro3 wrote:'02 forks are 2mm larger diameter than '99-'01
Is that the top or bottom triple or both?
it175 wrote:Ski is right on. I have 02 forks in a 04 clamp.
So 02 to 04 triples are all the same diameter?
The reason i'm asking is because i'm away from home until march and can't realy compare physicaly.
Posted: 10:57 am Jan 18 2009
by it175
Both.
Yes.
Posted: 06:10 am Jan 23 2009
by muddertrucker
thanks, now I can start looking
Posted: 01:32 am Feb 02 2009
by muddertrucker
I know I'm probably starting to get anoying with this but......does anybody know why they list all clamps for kx as 99 to 01, 02, 03 to 05. I know you said it works but I keep getting the feeling it won't ounce I try to fit it all together. Are aftermarket clamps different?
Thanks for the patience.
Posted: 03:40 am Feb 04 2009
by muddertrucker
To answer my own question: The only difference is the length of the stem wich is 10 mm longer (well actualy it's the part one frame that the stem goes into) on all 03's and above. So if you swap the stem 02 forks will fit 03 to 05 triples.
Posted: 08:03 pm Feb 04 2009
by MXOldtimer
Make sure you get the correct axle length for the T-clamps year. I bought an 05 axle and it was to short for my 02 T-clamps.
Posted: 04:02 am Feb 05 2009
by muddertrucker
I'm getting an 02 axle. This is an upgrade to my 97 usd's.
Posted: 11:29 am Feb 15 2009
by scootertrash_2
Hey, Im in the mid east too! and Im also going through the same headache in finding out about the right combination of parts to put the kx forks on to the kdx. Where abouts are you over here?
Posted: 11:18 am Feb 18 2009
by muddertrucker
Well.... does Mirage mean anything to you?
