Exhaust Collar?
Exhaust Collar?
When I bought my 2003 KDX220R it came with a spare exhaust. Just noticed today that this exhaust has a manifold collar for fixing to the barrel with studs. It looks identical to my standard exhaust apart from this collar and the end of the pipe (where it goes into the exhaust port is smooth has no grooves for o-rings.
I looked at the barrel and it has two threaded holes where studs could be fitted but I thought all 200/220's were fitted just with the o-rings and springs?
I am fed up with my standard exhaust leaking all the time (even with silicone) and was thinking about using this exhaust with studs to properly seal against the copper crush gasket. Can anyone shed any light on where this exhaust may have come from and any potential problems?
Hmmm.... a pic would help.
Wondering whether this is an exhaust for a jap import SR as that is the only model I can't find a fiche for.
Makes me think the exhaust has been previously fitted (hence the stud holes) or it is possibly a SR barrel? If that is the case, why the different mounting? Is one engine rubber mounted and one rigid?
That's really odd Tony... where are you located?
The other exhaust looks to be an SR model exhaust. Hard to tell from the pic but it resembles the exhaust I had on an old Yamaha DT 125 I had a few years ago... the sharp bend in the bell. Do you have an overall pic of that pipe?
I am in the UK, but my 220R is a Canadian model. We do get a few Jap import SR's here with the autolube and u/s down forks.
As I mentioned above, the pipe is identical, bends, brackets, welds etc apart from the header fixing. It may not look it in the pic as the pipes are not at exactly the same angle, but the sharp bend is not actually that sharp.
All in all, I would say that if you want to use the o-ringed exhaust.... The main reason for exhaust leaks is due to inproper neck angle going into the cylinder. It is pretty easy to determine if this is so by cleaning the cylinder mating surface and the end of the pipe. Using India Ink or something similar, coat the end of the pipes mating surface and install the pipe. Wait a while until the ink dries, then remove the pipe.... if the cylinders mating surface does not have a ring all the way around or is faint in a certain area.... then the pipe end can be manipulated to fit properly with a vise and a pipe inserted in the end of the exhaust.
Re: '220 is a Canadian model...'
..which, as far as I thought I knew, was NOT a US model bike.
A 200 (later 'H' models) from Canada? That would have been imported from the US at some point in time, so it WOULD have been a US model.
There was certainly some distinction along those lines.
Maybe you have an SR cylinder..maybe you have an SR bike.
Something I don't think I know...I'm sure I know...the SR is different in quite a few ways from the US model..and you aren't likely to ever know how many!
On this forum there are threads going round-n-round about that: 'Is a US import.' 'No it's not, it's an SR' No, it's a US import. I just need a PN for the SPEEDO..'
..stuff like that.
Bearings are different, water pumps are different..just a lot of stuff ain't the same.
THAT said....resolve your pipe leak problem and you won't care, right?
Align your pipe. Get a couple of good-sized steel bars that will fit either in (probably the cylinder end) or over (probably the stinger side). With the two bars inserted and applying (not a whole lot) of pressure in the direction needed, you can make your pipe fit much better than it likely does now.
Use your silencer as a guide (considering that IT isn't beat up). If you still have the stock silencer around..use that as as guide. It's not too likely to be wonky 'cuz it's tough..steel for one, not aluminum.
Start: Put your pipe in the cylinder, hold it with the springs. It should be square into the cylinder..and you can SEE that by simply looking at the first weld on the head-pipe and comparing it to the cylinder. You should be able to move the pipe on any 'line' (180º apart) and feel the end of the pipe clunk/snick/seat squarely into the cylinder. If not, look for where on the frame or whatever the pipe is getting hung up. Tweak it with your two bar tools to clear that up..so that your pipe DOES fit square in the cylinder.
Now...at least hold the silencer to the bike as it would be mounted. Note how the stinger and the silencer probably don't line up. Again, using your two pipe alignment tools..bend the pipe so it DOES line up.
When you're done, the pipe will still fit square to the cylinder, both mounting tabs will be easily accessible (no bending, tweaking, twisting of anything) and if (this for future reference or maybe an aftermarket piper) you're running a -30 pipe (larger diameter bell of the two FmF pipes), the pipe will not be touching the RH rad shroud.
If you have a decent vise (6-8" firmly attached to something), holding the pipe by one or other of the hangers may be helpful.
I've done all this..a few times. Generally when I am fed up with my...exhaust leaking all the time (even with silicone).
Of course...the teeny catch is I've done this with **edit courtesy of Mr. Wibbens. I was thinking of the spark arrestor cannister..which I've tweaked on some, too) aluminum** aftermarket pipes. It will work with the OEM pipe, too.
Once the alignment is at the least somewhat improved, silicone properly applied WILL keep that joint from leaking.
Which, by the way...I do notice nothing in the way of silicone on the joint of your pipe. Where is it? The 'properly applied' part will have a good lot of silicone bead when you take the pipe out. You either cleaned it particularly well (taking care to leave some carbon between the rings) or the 'properly applied' part wasn't.
**edit**I generally forget the 'e' and no 'e'...for anyone that already read it and know different...now it IS different!
..stuff like that.
A btw....but looking at the pipe pics...
The stud pipe looks to have a quite different bend to it from the other. You have tried an initial fitment, I presume? It does fit OK?
That it 'came with' wouldn't mean anything necessarily. Maybe the seller just wanted to clean out his garage. Heck...maybe HE (she/they/it) thought it was the original pipe, too............
I wasn't so much referring to the threaded holes as I was the bolt-on pipe being a 'spare'.
Re: 'Don't all....?'
Nope.
It appears the bosses are there...but not the holes. Let's find out if those really ARE bosses cast for studs.
Hey N8....drill a couple holes in your cylinder and see if it works!!
Nope.
Give me some creditcanyncarvr wrote:Maybe you have an SR cylinder..maybe you have an SR bike.
Definitely not an SR model, although I obviously don't know if the cylinder has been changed at some point.
Didn't mean to step on any toes. Apologies.
Re: 'As I mentioned above, the pipe is identical, bends, brackets, welds etc apart from the header fixing.'
I did miss that one altogether.
Can't know what the 'other guy' knows from a post or two. I do know questions have come up that a good number of folks have gone round and round and round over...only to find out the guaranteed know-it-for sure US bike (or 'R' in the case of the 220).....ain't.
What IS supposed to seal the bolt-up pipe? Pipes with collar affairs like that generally fit over a piece with o-rings on IT...like my Banshee fer example. A male end going against the flow is kind'a stupid.
Doesn't appear you got much info from the DRN crowd.....
I mean...compared to the tons of most excellent facts from HERE!
- Mr. Wibbens
are you trolling DRN?
