should be an easy one for you.my 220 is in need of rear wheel bearings.the parts diagram shows two bearings but the all-balls kit i've received has three.
the part no.on the kit is 17-1190.A and quotes that they are for kx125 (97-02)
kx250 (97-02) and kx500(94-04)
do i have the right set?
thanks.
rear wheel bearings
Re: 'do I have the right set?'
Whl Brg - Seal Kit - Rear
25-1223
That is the PN I get from the All Balls site for a 220 'A' model: http://www.goallballs.com/home.asp
Looking at one of the applications you list above (the KX250), the same site shows:
25-1224
A look-up of the PN you supplied gets this:
PART NUMBER FITMENT FOR ALLBALLS PART # 17-1190
No results found with those parameters. Return to dealer tools and try your search again
Look at any parts fiche to find out what your bearing size/type is. From BuyKaw:
92045 92045-1239 BEARING-BALL,6004X8JRLLX2/3A
Again...this is for an 'A' 220.
Do the bearings you have say '6004' on them?
Looking up a KX-250 on the same site:
So, this long and involved post (which doesn't note the time involved in doing the typing and searching I did on the same internet you have access to) tells you what you need to know, 'eh?
Cheers!
25-1223
25-1224
Cheers!
