I don't understand 'behind' maybe...you do mean on the INside of the gear? Right?
I see the drawing added..and where you put 'c-clip'. Don't know why there would be a clip there. The gear should run against the thrust washer, not a clip.
Look at it another way? The parts diagram does show three clips by item number...480, 480a, 480b. But...there are TWO 480s. So...a total of four clips (one of 'em on the top of the kicker lever, so not really what you're looking for).
The '480' on the idler gear assy isn't what you're after?
...it's not on the INside of the gear.
If I'd had my kicker assy apart, I'd understand what you're after, but I have not...and I don't.
Sorry for my ignorance..but the gear you're referring to rides on...what? The 92002-1601 bolt (shown in 'crankcase') that screws into the case?
Again...why would there be a clip on the INside on that 'shaft'?
See? I AM lucky to have never had to fool with mine. It just works!
knock wood.
You're welcome for the absolute lack of any help this post provides!
