Rear brake lever . . . . . Loose?
Posted: 08:37 am Sep 21 2008
by ihatefalling
Hey guys....on my '05 the rear brake lever has some play in it (from side to side, not in the hydraulic actuation). It seems that the retaining bolt is tightened all the way, but there's still a little slop. Am I missing a washer or something? Do they all do that? thanks... Oh, and my kickstand has some slop in it too, it's mounted up nice and tight, I guess is it supposed to have a little play in it??
Posted: 09:37 am Sep 21 2008
by Indawoods
Yes... they have to have play in them... they are not riding on bearings...
Posted: 07:58 pm Sep 22 2008
by ihatefalling
Indawoods wrote:Yes... they have to have play in them... they are not riding on bearings...
THX
Posted: 10:13 pm Apr 22 2010
by ihatefalling
waking this up.....play is getting worse. I guess the sleeve in the lever is just "wollowing" out.
Nothing to do but buy a new lever huh? OEM? Is thier an aftermarket that's better?
Thx . . . . .
Posted: 06:30 am Apr 23 2010
by KarlP
I doubt an aftermarket would be any better. It is more of a design issue.
The post on the frame that the pedal pivots on gets worn out of round, the inside of the lever does the same.
On a previous bike I grafted a KX style lever on after badly mangling the KDX one. I cut the KDX post off and welded the KX post on in its place. The KX assembly uses an aluminum lever and has o-rings and seals in the pivot to keep grease in. That was fine until I snapped the KX aluminum lever; the KDX lever is steel and can be straightened out multiple times.
A stiffer return spring will help keep the slopiness less irritating.
There are a number of options for a better kickstart lever.
Posted: 07:08 pm Apr 23 2010
by SteveWR450f
I had the same problem. I put a small washer on behind the nut and that helps a little to take up the slop. But as posted earlier, no bearing so keep it somewhat loose.
