Auto Driving Light on a Bike?
- jc7622
Ok, I'm thinking outside the box here so this may be a stupid idea. I'm sure you have seen the 8" race lights on bikes that are mounted in a round, metal frame. If not I can post a pic. It got me to thinking about whether or not it would be possible to fabricate a frame and mount a driving light (maybe a Hella or some brand) on the front of my KDX.
I used to have them on an old Land Cruiser I had and they were extremely bright. Most of these lights are 55w. If I upgraded my stator to 65w or 75w would it run one of these types of lights? Is there anything I may be overlooking. I'm good at building stuff but suck with electricity.
Why not?
With the stock stator your options are somewhat limited. After I busted my OEM headlamp, I foolishly "upgraded" the headlamp to 55w but not the stator. It didn't work very well. I think the stock stator will support a 35w lamp and no more.
Doesn't amperage matter?
- jc7622
Like I said, I am pretty stupid when it comes to electricity. I dunno.Indawoods wrote:Doesn't amperage matter?
The link below is a light that is kind of like what I am talking about. I could fabricate some mounts to hold this frame. Unfortunately this light is 100w and as far as I know the KDX stator can only be upgraded to about 75w. Maybe I could find a lower wattage bulb to fit in it.
BTW, I just learned that the Trail Tech lights are in fact Hella lights. Someone who has one told me that if you peel the Trail Tech sticker off Hella is etched in the light underneath it.
http://www.sidebysidesports.com/solahaspordr.html
- kawagumby
"By the definition of the units of ampere and volt, work is done at a rate of one watt when one ampere flows through a potential difference of one volt."
Front light @ 30w + rear @ 10w = total 40 watts min available (the generator may provide more power than that)
40 watts/12 volts = 3.3 amps minimum
If you don't need the tail light you'll have a little more power for the front light. Also, you may be able to find lower voltage bulbs that can handle the 12 volt system getting you even more brightness. If the bulb can handle the voltage it'll be brighter but not last as long. Here's a link to an outfit that sells various kinds of bulbs, including headlite types of varying voltage spec: http://www.taillightking.com/light_bulbs.htm
- jc7622
Ogre wrote:The change was done by the PO, but I am pretty sure the original was sent off.
I have a revised wiring schematic for the bike from Baja Designs that calls it out as 130W.
I have run 2 55w bulbs up front with tail & brake lights working just fine so I don't doubt the rating.
Unfortunately Baja Designs no longer does the 100w stator rewind. He said that it requires the use of a thicker armature, which they don't have any more and even if they did have them it didn't matter because they don't have any techs there now that knows how to do it. They said the best they could do now with the parts and employees they have is 75w. That sucks. I need to figure out some way to do one of these up to 100w.
They said if I wanted brighter lights I would have to use one powered off a battery with a run time of 3.5 hours.
Use a multi-meter and then you will need to use the multi meter to measure as a part of the circuit on the output from the stator where it connects into the harness in order to get the number of amps in the system. Then multiply this by 12 volts and you'll get a close approximation of the number of Watts put out by your stator. The regulator should hold the voltage around 12 volts. Anyways, thats how I would do it. Please correct me if I am wrong, it has been a while since I have had to do anything other than resistance.
I got mine done by Fredette last winter. It is at 85 watt. It runs my 60 watt Acerbis and the stock tail light/brake light fine. When I was looking around, they were the highest wattage that I could find.
1998 KDX 200
- 2000 KX 125 front end.
- Bills Pipe
- RB Head and Carb !!!
1987 Husqvarna 430XC
- Up-Tite Pipe
- Bills Pipe
- Up-Tite Pipe
