Clutch noise...
Posted: 05:48 pm Apr 13 2005
by Indawoods
I know...I know... but I gotta know!
My clutch sounds like a drum roll idling in neutral... pull it in and you can still hear it just not as bad.
I completely tore it apart tonight and I cannot find out whats wrong... is the basket warped possibly? It actually just sounds like the plates hitting back and forth on the basket. I can't find any wear on the basket though. Could it be the plates out of tolerance or weak springs?
It's really kinda driving me nuts listening to it...
And I don't think I'm ready for a automatic Ski!
Posted: 06:02 pm Apr 13 2005
by m0rie
You running the whole quart of oil in the tranny?
-Maurice
Posted: 06:06 pm Apr 13 2005
by Indawoods
Yup! Always have... after I put it back together ..it seemed quieter. Proly my imagination....
Posted: 06:18 pm Apr 13 2005
by motorider200
Mine and my brothers both make that noise. I think it is just a KDX trait.
Posted: 06:40 pm Apr 13 2005
by Indawoods
My 92 had a similar noise...just not as loud and that's what I was used too. I may take the basket into a machinist and have him check it for balance and trueness or pick up a Hinson cheap.... yeah....RIGHT!
Posted: 12:23 am Apr 14 2005
by quailchaser
Ah, the dreaded rattling of the clutch.
I'm pushing 1800 miles of extremely sloppy riding of single track on my '03 (with the original clutch
) and it has made that noise from day one. Some days it sounds louder than others.
My fix:
I put my helmet on, start the bike, and then just start riding (I've decided to never start the bike w/o my helmet on)....I never hear that noise and totally forget that it even makes it.
la la la la la la la la la la la...I can't hear you!
By the way...if you find that cheap Hinson, please let us all know where!
Later
Robb
Posted: 10:29 am Apr 14 2005
by dave04kdx
Good one Robb, it's not a problem if you can't hear it
My solution is to try and ride with someone who has a louder bike than mine!
would have been concerned with my 04 if I hadn't heard an H model rattle.
My old 88 KDX had half a million miles on the bottom end and the original clutch.
Last time my brother (current owner of the 88) went riding the 88 was more quiet than my 04 :eek:
Has anyone isolated the noise? Is it the clutch or tranny, bottom end or a combo of all?
Posted: 10:50 am Apr 14 2005
by motorider200
I'm pretty sure it is the clutch because when you pull the clutch in the noise gets quieter(at least on mine).
Posted: 10:53 am Apr 14 2005
by Indawoods
It's the clutch.... No reason why it should be so noisy. If I can fix it... I am going to make it a business! Should make a fortune!
Re: Clutch noise...
Posted: 11:27 am Apr 14 2005
by skipro3
Indawoods wrote:And I don't think I'm ready for a automatic Ski!
Gee, mine doesn't rattle. But Doug's does on his KX500. I think it's his pipe and not his clutch though.
If you get an auto clutch, then ride it until you feel it is instictive, (about 4 or 5 rides) Then put on the hand operated rear brake. That will also take a few rides to get used to. After that, your riding will be so improved AND no one else will want to ride your bike!!! I let guys try mine and they get scared because their muscle memory is all wrong for this setup. HA!!!!
Posted: 11:37 am Apr 14 2005
by canyncarvr
re: cheap Hinson.
Don't think 'cheap' happens...but do keep in mind that when you buy a Hinson basket, you do NOT get the
assembly that includes the gear and it's little mounting rubbers.
I think Mr. Ron takes Hinsons and puts them together with your hardware...or may use his own ....I'm not sure about that. Anyway, if you're leery of drilling out rivets on the oem basket and messing with the 'lil rubbers...there are options.
Inda: Consider yourself unusual if you haven't heard this racket all the time. Maybe now you can consider yourself 'normal' like the rest of us!
Nah! THAT couldn't happen!!!
Posted: 12:00 pm Apr 14 2005
by Indawoods
I've heard it... but it seems it's gonna jump outta the case compared to the 92....
P.S... What rubbers?
Posted: 12:10 pm Apr 14 2005
by canyncarvr
Little washer iso-mount thingys between the plate (gear) and the basket.
Posted: 12:14 pm Apr 14 2005
by Indawoods
Think that could be the problem?
they are not in my exploded view in the manual...
Posted: 05:02 pm Apr 14 2005
by Indawoods
I tore apart my clutch again tonight and found that it was assembled incorrectly from the git go... This time I assembled it by the book.
Problem 1. The last clutch plate was not in the offset grooves.
Problems 2. The inside rings outside edge of the two last rings to be installed was pointing outside instead of to the inside. (hope that makes sense?)
Problem 3. Last thrust washer was installed backwards.
Possible Problem 4. The washer that goes under the throw-out assembly is a little bitty diameter washer instead of the substantial washer shown in the manual...
anyone take note of this?
Possibly throwing off the tolerance causing the noise? The actuating rod moves up and down a little while the bike is running... making me think something is wacked... I gotta figure it out... I've done everything else to the bike... I need a problem to solve!!
Posted: 11:40 pm Jun 12 2005
by GregS
Late chime-in again... I searched on 'clutch noise' and found this thread.
Here's what I'm experiencing: If I rev hard and take off (e.g. aggressive quick climb or speed burst), I'll sometimes get a loud 'chirp' or squeel. Very brief. Actually, it sounds a bit like a bad fan belt on a car -- but a very short version (thus calling it a 'chirp').
I was hoping that it was normal when I saw this thread heading, but maybe not... Gosh I'd love to ride a relatively new KDX to see how it compares to mine. I really have no baseline.
