I just ordered a gallon of tha AMSOIL Dominator..... then I got to thinking that maybe I should have ordered the Interceptor oil. I didn't check the specs or the ratings before I ordered because I have heard everyone using the Dominator oil.
But, the Interceptor oil appears to be a closer match for the KDX's requirements. Emphasis on clean power valves and less wear.
Should I cancel the order and get the Interceptor instead???
*** Administrator //*** ****'95 KDX 200/****
I've run the Interceptor in my snowmachine for the last two years and it is excellent at keeping the power valves clean. 100 % satisfied i.e. nice film left, no excessive wear noticed, etc, etc. (02 700 RMK.)
However I run the Dominator in the 2-cycle bikes because it is colored and you are sure your pouring from the right can and you know the oil is in it. The interceptor is colorless.
Ran the series 2000 until they changed it to the Dominator series. Have run the Dominator series since. I think you will be happy with either one from the protection standpoint.
MX2T is discontinued!
That's what I have left over from last year.... great stuff but no longer available. It's colorless in gas too! But I use a special can for my premix so I don't worry about it 'cause I mix it when I get gas.
Just got my carb back from Ron tonight.... stuck it on there...got gas and fired on the second kick and it ran perfect for 10 minutes when I shut it down ... part of the break in process. Checked the silencer... nothing... nothing at all!
First time ever this has happened! Going riding next weekend to break her in the rest of the way...but all indications are good that she's golden! It just purred and purred!
BTW... my lighting circuit works PERFECT!
The reason I ask if I should change my order is...that I bought a gallon of it!
That'll last a while and I am in the break in stage. Of course I all ready loaded it with the Mobil MX2T because I couldn't wait to fire it up and start breaking it in.
I'm probably just a overly protective rider!
Some Autozone stores now have the new version of the old Mobil MX2T. The new Mobil Racing 2T is available in quarts (darn), has a red dye in it (yeah) and sells for $6.99 (in different).
Well... I changed my order to a gallon of the Interceptor AMSOIL. Gonna try it out and should last me a while instead of wondering if the Mobil is in stock or not. It works out to be a little cheaper than the Mobil 1.
Should use less at 50:1 right?
I know... I don't like that rate but I figure if it's what they recommend they best stand behind it!
I let you all know...
Oil ratio's is a lot like asking what mx fender makes your KDX the fastest in a drag race but for what its worth i've been running Golden Spectro @ 50:1 since day one as thats what the bottle recommends. I haven't seen any ill effects yet.
I'm sure that stuff is great. Either one. AMSOIL makes great stuff!! Just don't think I could ever do that 100:1 AMSOIL I'm sure 50:1 is fine.
Still a MOTUL800 fan.... Not exactly easy to find, but I can at least go get some locally if I need it....They say 50-60:1, but I still run 40:1 and jet accordingly. I think you could run 20:1 and still not foul plugs if you're jetted right.
We run 12:1 bean/syn mix in the karts w/o probs, but the H/L hand adjustable jets and high-speed electric starter box are nice for that
I was running Golden Spectro @ 40:1 until my last topend. Goo city. I'm on my second Gallon of Interceptor running @ 40:1. We'll see at top end time in 6 months if I'm really happy with Amsoil.
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
