1995 KDX200 Shock Internals Pictures
Posted: 02:07 pm Mar 28 2005
Just in case anyone is interested, here are some pictures of the internal components of a 1995 KDX200 shock. These are from when I worked on IndaWoods' shock recently. 1989 - 2005 KDX200 / KDX220 shocks look similar internally. 1988 and older shocks look a good bit different.
Posted: 02:29 pm Mar 28 2005
by Indawoods
Ah... what a beautiful shock!
Posted: 03:11 pm Mar 28 2005
by canyncarvr
Looks like it needs to be revalved to me.
Too many flat washer thingys...
Posted: 04:26 pm Mar 28 2005
by skipro3
That's not the stock valve, is it?
Posted: 05:20 pm Mar 28 2005
Hi, skipro3. Yes, that is the stock piston. That is the top view (rebound side) in each picture.
EDIT: skipro3, here are a couple of pictures of the stock piston from a 1989 KDX200 shock. The first picture is the rebound side. The second picture is the compression side.
As best I can remember, the 1989 and 1995 pistons look the same. The stacks are different, but the pistons are the same.
Posted: 10:14 pm Mar 28 2005
by m0rie
Jason - Did you note (write down) the differences in the shim stack for the 95+ shocks vs the 89-94 shim stack?
-Maurice
Posted: 08:57 am Mar 29 2005
I think I did. I would suggest you just check out the
http://www.suspensionnetwork.com to compare them. He has valving listed for various year model KDX's. It would be a lot quicker than me trying to find them.
