Jetting on the Hybrid
Posted: 12:26 pm Jan 22 2008
by KarlP
I've got a KDX220 motor in a '99 CR 250 frame with a modified '96 cr 250 exhaust on it. To get the exhaust to fit, I had to add ~2" of straight just outside the cylinder.
The motor in stock form ran very well. I ran jetting of 142 main, 45 pilot and the stock needle (1173). It had an occasional stumble right of idle under load, but nothing I couldn't ride around.
I swapped over my RBD carb and head from the real KDX, so my jetting is now 150 main, 38 pilot, CEK needle with the clip in the 3 position.
With the mixture screw 7/8 out, the stumble under load off idle was more pronounced. With the mixture screw 1-3/8 out it is less but still there. In fact, I can make it happen if I want, so it is pretty predictable. The motor has more power everywhere, especially on top.
My question is, which way do you all think I should go with the jetting? I will gladly sacrifice some of that top end and some of that hit for more and cleaner bottom, if I have to. I realize the pipe is a complete unknown.
Thanks for any help!
Posted: 03:38 pm Jan 22 2008
by fuzzy
May need a needle with a slightly leaner 'straight' section, or more taper. What needle is in there now? May need a slightly leaner slide, but start w/ the needle for sure. All to do w/ jetting for the pipe. Probably a lot easier to work w/ the carb then re-do the pipe. I will add that you went the right way w/ the pipe if you had to do so....A shorter header will increase top-end power, and will also run hotter. Basically, you installed a 2" 'torque ring,' and I must say I do find it interesting that you have great top-end at this point. Guess that it's due to the fact that it was a 'rev' pipe for a 250 to start with. Musical pipes is fun! Never know what's going to happen. :mrgreen:
Posted: 04:49 pm Jan 22 2008
by KarlP
I've got the CEK in there now. Would the stock(1173) needle be going in the right direction?
The pipe geometry does not look a whole lot different than the stock KDX pipe. The straight inlet section on the CR pipe was pretty short.
Posted: 12:37 pm Jan 23 2008
by fuzzy
Take a look at this chart. It is a necessity for picking needles:
http://www.sudco.com/keihin_jn3.html#pj
You're probably going to need something slightly unorthodox for what you see on here all the time. I'd say grab a few, and see what kind of results you get. I'd start with maybe a CEN, BEL, BEN
Posted: 08:37 am Jan 24 2008
by KarlP
Thanks for the chart, Fuzzy. Very handy. Any Idea where the stock 1173 needle falls in there?
Last night I changed to a 40 pilot and the stock needle. Off-idle response is worse.
The way I'm defining performance is to idle along in 3rd and snap the throttle to 1/4 or 1/2 or even full. I would of course like it to pull clean
Posted: 09:19 am Jan 24 2008
by krazyinski
smaller pilot first 35, make one change at a time. 0-1/4 is pilot circuit, 1/4-3/4 is needle, 3/4- 1 is main jet. they do over lap some what so a change in one can effect the other.
the stumble is a rich condition off idle ? or a lean condition?
sputter gurgle =rich
bog = lean
by adding to the exhaust you change the dynamics of the pipe
so abnormal thinking and jetting will apply to an extent.
Posted: 09:53 am Jan 24 2008
by KarlP
Abnormal thinking is O.K. with me. Just ask my wife..... :blink:
Rich or lean, I am not sure. I think lean (BuuuWAaah?)
I bet the 1173 needle is leaner than the CEK?
I'll change back to the CEK needle, clip in the middle.
Posted: 01:37 pm Jan 28 2008
by KarlP
I've changed back to the CEK, clip at three from top
Jetting CEK-3, 40, 150
All is right with the world :supz:
The stumble is gone, the midrange pull is clean. Suprising what a difference that needle makes. I think I'll pick up a DEK, just for the heck of it..
Now to check the main.
Posted: 10:27 am Jan 29 2008
by fuzzy
Sweet!
