KX 500 fork conversion project bike finally gettin goin
Posted: 02:45 pm Nov 07 2007
by TopperHarley
This one was a drop in fit. 2000KX500forks in an 03KDX frame. Just had to modify the stops a bit. I have been thinking about and gathering parts for this bike for a year and a half. Finally getting her together.
some pics here http://kdxrider.net/forums/modules.php? ... _album.php
Posted: 03:49 pm Nov 07 2007
by fuzzy
Totally drop in?! :supz:
Posted: 04:04 pm Nov 07 2007
by TopperHarley
bearings and stem were same as KDX. No trip to the machine shop to get stem pressed out and into KDX lower. also, the forks are a bit shorter than KX125&250 forks. Therefore, you do not have to set them so high above the top clamp to get the bike to sit level.
Posted: 11:33 am Nov 08 2007
by fuzzy
That rocks. How big are they (mm)? Full comp/rebound adjustments?
Posted: 02:19 pm Nov 08 2007
by TopperHarley
inner tubes ar 46mm. yes, the have adjustable comp. rebound damping.
Posted: 02:21 pm Nov 08 2007
by TopperHarley
I may be wrong on the length now that I compare to my 03KX250 forks.
Someone else told me they were shorter. I took their word for it.
Posted: 02:38 pm Nov 08 2007
by 2001kdx
There's a member one here with a KX500 conversion. Do a search for it, but I'm sure whoever it is will surface soon.
Posted: 06:57 pm Nov 08 2007
by TopperHarley
I did fins someone who had done a conversion using KX500 forks with a YZ triple. they ended up changing their tubes to YZ USD because the valve stacks were more versatile thank the KX500 were. I will be going gold on mine, when I can afford it.
Posted: 12:11 am Apr 01 2008
by dmcc
How has the KX500 triple clamps/forks conversion worked out? Did you have to make any mods besides the stops? How about shims under the top clamp? I just bought a 1999 KX500 forks and triple clamp, waiting to get them here to see how they fit.
Posted: 02:29 pm Apr 02 2008
by TopperHarley
im not sure if the 2000 and 1999 kx 500 forks are the same. dealer may be able to tell you for sure.
Posted: 03:26 pm Apr 02 2008
by dmcc
How has yours worked out?
