Thanks Idaho, that bit about the valving changes in the later big bore years explains alot. Thanks for shedding some light on the stack. What is BNG years? and who is Dusty?
Inda, I appreciate your criticism. When I purchased these forks they were in need of a complete overhaul. both seals were leaking ,rt leg very bad. it was lacking 1/3 of its oil. I broke them down and installed new bushings, seals, wipers and o-rings. The base valves were covered with sludge and stuff. I wasnt about to put them back in without breaking them down and removing all sludge and chunks of deteriorating teflon which had shedded of the bushings and worked its way into the valve and shims etc. I pulled the mid valves out but they were not too bad. Probably because of gravity. If I had just bolted them on and taken a ride to see where I was, It would have been face down in the dirt with fork oil coating my righ radiator and burning off of my exhaust. Once I got them apart and was confused about the BV shims, I has to ask about it b4 I reassembled them. I will probably install them with 1 less 22mm, per Idahocharlies suggestion, and see how they work and go from there. BTW, I will be getting into my 2003 KX forks soon.same year as your kx125 forks if im not mistaken. Did you get around to revalving or respringing yours? I would like to know how your BV were stacked and what you endedup doing with it etc. If mine has an extremely stiff MX stacks in it and yours had the same and it was necessaqry for you to remove, say, 8 of the twelve 24 mm shims to get the compression dampening to comply with woods riding, I would probably remove those 8 shims and start from there rather than retest something that has already been figure out. Why rub two sticks together when Vince has a BIC in his shirt pocket.
heading to st joe on sunday and then Wachita on Mon. the 12th
2005 KDX220 mine
