I have a quick question that may result ( I hope) in long detailed answers.
I have an 04 KDX22R. Now why is there so much info on KDXs up to about 94 or even 03. I know they are no longer making them, but even as far as aftermarket upgrades go it seems that the newer years are really limited in what is available. That even seems to apply to tips and tuning tricks.
I've also looked at the spec sheets for the KDX 200, KDX 220 and the KDX 220R . What is the difference between these bikes other than displacement. Suspension? I've literally gone over the specs side by side and the only thing that Kawasaki lists is the engine being a bit bigger on the 220. What is the "R" in 220R?
These seem a bit trivial, but I'm simply curious.
I'm also planning on upgrading here and there as time progresses. I've already done the aftermarket levers, handlebars, air filter, picking up some new brush guards today ( stock plastic is okay for guarding against little stuff, but big trees will still smash the hands). New pipe is in the works in the near future. I'm looking at a Pro circuit. Anyone have any recommendations. I've heard the FMF tiorque is a good pipe for the 220. Then again, most of the info I read about is geared more towards the earlier models.
Any if would be greatly appreciated.Thanks
After a 12 year absence from motorcycles
- xagentman
Boy, did you come to the right place.
I would like to say welcome back to riding! And know right off that your 2004 220R is the same as an 03 and even farther back. one of the best things about the KDX is that it is largely unchanged over the course of the years.
That being said... Most of the modifcations that are done to the KDX are Pipe, Carby, Head, and Forks. All of these yield amazing results. I would check out these places for modifcations:
http://www.rb-designs.com/
http://www.kdxrider.net/forums/viewforum.php?f=110
http://www.kdxrider.net/forums/viewforum.php?f=104
best of luck... there is a ton of info here and with the use of the "search" button you will find everything you have ever wanted to know about the KDX and more.
-Agent
-Agent
==05 KDX220R==
Re: 'I've also looked at the spec sheets for the KDX 200, KDX 220 and the KDX 220R . What is the difference between these bikes other than displacement.'
'H' model 200/220 differences: 35/33mm carb size (and therefore jetting), piston size (bore is different, stroke the same), port timing (port height, angle, etc). The 220 comes with an O-ring chain, the 200 does not. That covers it I believe.
The 220R was made from '97-05 (as stated)..according to the Kaw website.
The 220R is commonly referred to as a 220..dropping the 'R'. What does the 'R' stand for? I don't have an answer for that. There ARE 'R' bikes overseas that are NOT the same as stateside 'R' bikes. Presumeably an Arizona bike is a US bike. Wouldn't have to be. Overseas models (generally..maybe most of the time..maybe even always) are oil injected (no premix), smaller carbed than the US model, have a different lighting system, and 'dash' controls.
Pipe? Everyone has their own favorite flavor. The bulk of 220 riders use a REV FmF because the 220 (due to port design/carb size) tends to be weak on top. A PC (plain PC..no II or SST) is more akin to the FmF rev than the FmF torque profile.
The following is from CDave's site: http://justkdx.dirtrider.net/
Note no 'R'..not because he's referring to a different bike..but just dropped the letter.
Year
Model - Series
Major Changes
1979 - 1980
KDX400 – A1 / A2
Introductory year for the big bore KDX
1980
KDX250 – A1
Introductory year, Dual shock rear suspension
1980 -1982
KDX175 – A1 to A3
Uni-Trak single shock rear suspension
1981
KDX420 – A1
Increase in displacement
1981 - 1984
KDX250 – A2 to A5
1982
KDX450 – A1
1982 -1983
KDX80 - B1 / B2
Introduction of the baby KDX
1984 - 1985
KDX200 – A1 to A3
Introductory year, all new KDX 200
1986 KDX200 - C1 Bold New Graphics
1983 - 1988
KDX80 - C1 to C5
1984
KDX200 – B3(RED)
An optional red KDX200 is made available
1986 - 1987
KDX200 - C1 to C2
KIPS Valve equipped with a front disk break
1988
KDX200 – C3
35mm Keihin PKW carb. introduced
1989 - 1993
KDX200 – E1 to E5
KX style frame, liquid cooled, rear disk added
1990 KDX200 (White) An optional white KDX200 is made available
1991 - 1994
KDX250 – D1 to D4
Parameter frame with inverted fork
1993
KDX200 – E5
Inverted front fork added
1995
KDX200 – H1
All new KDX with perimeter frame
1996 - 1999
KDX200 – H2 to H5
Stronger clutch springs
1997 - 1999
KDX220 - H4-H7
Increased displacement, smaller 33mm carb.
Consider the source...but this might be of interest:
http://justkdx.dirtrider.net/200vs220.html
Year
Model - Series
Major Changes
1979 - 1980
KDX400 – A1 / A2
1980
KDX250 – A1
1980 -1982
KDX175 – A1 to A3
1981
KDX420 – A1
1981 - 1984
KDX250 – A2 to A5
1982
KDX450 – A1
1982 -1983
KDX80 - B1 / B2
1984 - 1985
KDX200 – A1 to A3
1983 - 1988
KDX80 - C1 to C5
1984
KDX200 – B3(RED)
1986 - 1987
KDX200 - C1 to C2
1988
KDX200 – C3
1989 - 1993
KDX200 – E1 to E5
1991 - 1994
KDX250 – D1 to D4
1993
KDX200 – E5
1995
KDX200 – H1
1996 - 1999
KDX200 – H2 to H5
1997 - 1999
KDX220 - H4-H7
- C George
Great info for anyone getting back into riding. Worth a bump on an old post.
Miss your experienced input Canyncarvr
