BV mod for hare scrambles.
FRYSPEED
I have put my 90 kdx engine into a 98 kx 125.Ive made it all with bits from ebag.The front forks are from a 04 kxf250 with 02 kx250 Tag clamps.Ive raced a few times with it and find the front slightly harsh.Ive set the compression adjusters to the softest setting.Next step I think is to mod the Base valve.Any suggestions as to how many shims to take out to make it more compliant.The springs are correct for my weight.
- krazyinski
take the big ones out but it will still be harsh from the mid stroke, drop the forks have them re valved. money worth spending. I jacked with mine for six months and thought I had them close. after I had them don by pro action I found I was way off. nothing but pure compliance now. cant feel anything under 6 inches on the trail.
