Check out my plug chop
Questions and Answers about the best carb and Head mods available for the KDX.
strider80
Post by strider80 »
Sorry for the butchered lathe job, the steel is so soft the cutoff tool dug in and pulled it out of the chuck.
This was yesterday, ~1500ft , 53degF, slight uphill on pavement, 6th gear pinned for 5 seconds (it was a bit exciting).
2000 KDX200
Mods:
RB carb and head mod, CEK #3, 152 main, 40 pilot
FMF rev, TCII, Boysen power reeds, FRP torque spacer, modded airbox lid, Interceptor @ 40:1, 92 pump gas
So what do you guys think?
Click to enlarge:
2005 KTM 250EXC
2000 KDX200 (gone)
KDXer
Post by KDXer »
Looks very good to me. Not too rich and not too lean, 'bout perfect I reckon.
Compliments to Skipro for the pics and comments.
I put up a couple of photos in my gallery. One is rich, like yours and one is slightly rich but runs good.
Basicly, a WOT read should show the black band as if drawn on with a pencil.
145 main
150 main
After 100+ miles (not sure which main, guessing 145)
Compliments to BJH.
A tad rich
42 and 1/2 out on the air screw.(Plug looks brand new at idle only)
7 slide ( Plug looks rich)
Needle@CEG-4. ( Bottom Mid- range wheelies)
Main at 155 (Plug looks lean to me see what you think)
1400 feet elevation at 50 degrees F
Compliments to Morie for the link below. It came from the thread in the 2nd link.
http://www.dirtrider.net/forums3/showth ... light=plug
http://www.kdxrider.net/forums/viewtopi ... &&start=20
strider80
Post by strider80 »
Thanks Trev, I should probably try a 150 just for fun. Seems like a 150 would be good bet for summer time.
2005 KTM 250EXC
2000 KDX200 (gone)
strider80
Post by strider80 »
Do I need to machine off more steel to see the full mixture ring?
2005 KTM 250EXC
2000 KDX200 (gone)
KDXer
Post by KDXer »
strider80 wrote:Do I need to machine off more steel to see the full mixture ring?
Wouldn't be a bad idea. :wink:
I just spin mine up in a drill press, move a hacksaw blade back and forth until I get a good groove in it where I want to cut it off, then I grab a large nut and cross thread it onto the threads, then finally put a spanner on the plug and cross threaded nut and by twisting them against each other it snaps off cleanly.
Jeb
Post by Jeb »
You could drop the main a size - especially since you're headed toward warmer weather - and you still ought to be alright.
CLICK FOR PICS!
The ring is a good bit thicker (wider) than 1mm..although a 1mm ring is too close to suit me.
Using ski's ring change with one jet change as a guide, dropping to 150 should make things about right.
I run a 152 in cooler temps, most of spring and summer I run a 148.
Something tells me I've read that torque spacers give somewhat confused plug reads....
Re: 'Do I need to machine off more steel to see the full mixture ring?'
No.
But doing so would make it EASIER to see.
Happy trails!
AZRickD
Been thanked: 3 times
Post by AZRickD »
I'll bet you're pretty close. I use a 152/40 CEK-3 in the "cooler" months down here in Phoenix and a 150/38 in the "warmer" months. For one or two months in the freakishly-hot Arizona summer I drop down to a 148/35 and adjust the A/S just so my choke will work right.
Anyway, your chop looks just a little thicker than mine, but not much. Give up a little HP for some engine life, I suppose.
Rick
strider80
Post by strider80 »
I think I will leave the main for now. I am going to try a 38 pilot next time out. I know I should not jet by spooge/smoke, but the bike is slobbering quite a bit on the silencer, more than pre-RB. Seems rich to me down low.
2005 KTM 250EXC
2000 KDX200 (gone)
