But once i put the new "KDX/X" forks on the frame, the stem was a BIT to long AND the KX top triple clam was to damn big for the stem. Not by much, and a 2nd bolt and washer underneath the 1st one for the top of the triple clamp solved this problem. At this point i was very excited... i though this would be easy...
Next came the wheel, i found a way to use the stock wheel, and i found a diferent axel, from some old 1970's dirtbike that will work fine. Just a few bushings and everything will be fine.
By the way, if you want to use the stock wheel on the KX forks, you need bearing with a larger INNER cone...and just a longer axel, and once you figure out the proper spacing using some good bushinsg you will be Good to go...
So now i thought everything was done, just mount the brake Caliper. Well thats where everything hit a HUGE snag....The brake caliper mount does not even line up to the KX mounts...Wish someone told me bout that...
So now i figure i can drill and thread the ONE needed hole into the mout to make it work, but that might compromise the strength of the metal and the mount...That or i buy a 1995 KX Brake Caliper and set up on ebay...(which i might do) Do ya'll think a 95 Caliper will work on 96 forks??? I think it will... Or can i get away with drilling inot the mount???
Thats my adventure so far what do ya'll think!?
