Was finishing things up today went to put the KDX rotor on the KX hub and screeeeeeeeeeeeeeeeeeched to a dead stop.
My 06 KDX uses 8mm bolts w/ large head, KX uses a small 6mm. Now I have to come up with a front rotor, DAMN!
No riding this weekend.
I thought about that but there isn't much meat left on that KX hub around the bolts.kawagumby wrote:Just drill out and tap the KX hub to accept the KDX rotor and bolts. That's what I did and it worked great.
I worried about that too, but there is enough meat left to do the job. Notice that the mounting tabs are tapered, if you look at the narrowest section they seem too small, but the balance of the tab is more than adequate IMO. The slight difference in bolt diameter just isn't enough to make or break the design strength IMO. I use a tusk non-floating rotor on another bike (a kx), and I have had trouble with it developing too much axial runout...squeak, squeak, squeak. I keep having to tap it back all the time - to keep the noise down at low speeds.MXOldtimer wrote:I thought about that but there isn't much meat left on that KX hub around the bolts.kawagumby wrote:Just drill out and tap the KX hub to accept the KDX rotor and bolts. That's what I did and it worked great.
I also thought about redrill'n some holes in the rotor but once again there wouldn't be much meat left on the rotor itself.
kawagumby wrote:I worried about that too, but there is enough meat left to do the job. Notice that the mounting tabs are tapered, if you look at the narrowest section they seem too small, but the balance of the tab is more than adequate IMO. The slight difference in bolt diameter just isn't enough to make or break the design strength IMO. I use a tusk non-floating rotor on another bike (a kx), and I have had trouble with it developing too much axial runout...squeak, squeak, squeak. I keep having to tap it back all the time.MXOldtimer wrote:I thought about that but there isn't much meat left on that KX hub around the bolts.kawagumby wrote:Just drill out and tap the KX hub to accept the KDX rotor and bolts. That's what I did and it worked great.
The "floating" design is superior (at least with a four bolt design)...and I have already put about 25 hours on the drilled-out KX hub, mostly hard riding in really rough single track and have had no issues at all.
Just my experience, FWIW.
